<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is it possible to enable debug logging on FusionAuth?]]></title><description><![CDATA[<p dir="auto">I'm looking to get more information from the FusionAuth server. Particularly request and response logs during development would be great to help further understand integration issues with client applications or libraries.</p>
<p dir="auto">Is this possible via environment variables or possibly the <code>additional-java-args</code>?</p>
<p dir="auto">Personally, I'm working with Docker Compose and after FusionAuth starts up, I see no further logs to provide me any additional information.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/104/is-it-possible-to-enable-debug-logging-on-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 19:46:46 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/104.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 May 2020 20:29:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is it possible to enable debug logging on FusionAuth? on Thu, 21 May 2020 21:35:52 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Per the configuration reference, you can set <code>FUSIONAUTH_ADDITIONAL_JAVA_ARGS</code> for</p>
<p dir="auto">Any additional arguments that you want to pass to the Java VM where this service will run.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/reference/configuration#environment-variables" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/reference/configuration#environment-variables</a></p>
<p dir="auto">I know this was used to tweak proxy settings here: <a href="https://fusionauth.io/community/forum/topic/76/can-i-use-a-proxy-with-fusionauth">https://fusionauth.io/community/forum/topic/76/can-i-use-a-proxy-with-fusionauth</a></p>
<p dir="auto">I'm not sure how to tweak the logging settings via java arguments, but maybe that gives you a place to start?</p>
]]></description><link>https://fusionauth.io/community/forum/post/231</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/231</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 21 May 2020 21:35:52 GMT</pubDate></item><item><title><![CDATA[Reply to Is it possible to enable debug logging on FusionAuth? on Thu, 21 May 2020 20:50:07 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-issues/issues/639" rel="nofollow ugc">Found out my issue</a> without logging, but this would still be a great tool for local debugging.</p>
]]></description><link>https://fusionauth.io/community/forum/post/230</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/230</guid><dc:creator><![CDATA[matt]]></dc:creator><pubDate>Thu, 21 May 2020 20:50:07 GMT</pubDate></item></channel></rss>
