<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Where to find the option &quot;Require registration&quot;]]></title><description><![CDATA[<p dir="auto">In this guide <a href="https://fusionauth.io/docs/v1/tech/core-concepts/authentication-authorization/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/core-concepts/authentication-authorization/</a> it is mentioned that you can set the option "Require registration" to true in order to avoid the generation of a jwt when a user is not registered in the given application.<br />
But neither in the UI nor in the api documentation there is any optionlike this.</p>
<p dir="auto">Our current problem is that one user can have multiple registrations but during the passwordless when we pass the application id a jwt should only be generated when the user is registered in this application.</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1171/where-to-find-the-option-require-registration</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 16:07:16 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1171.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Jul 2021 10:32:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Where to find the option &quot;Require registration&quot; on Fri, 03 Sep 2021 19:03:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/982">@florian</a>  Glad you found it!</p>
]]></description><link>https://fusionauth.io/community/forum/post/3646</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3646</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Fri, 03 Sep 2021 19:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find the option &quot;Require registration&quot; on Wed, 01 Sep 2021 08:44:54 GMT]]></title><description><![CDATA[<p dir="auto">Perfect, thanks for the explanation.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3628</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3628</guid><dc:creator><![CDATA[florian]]></dc:creator><pubDate>Wed, 01 Sep 2021 08:44:54 GMT</pubDate></item><item><title><![CDATA[Reply to Where to find the option &quot;Require registration&quot; on Tue, 03 Aug 2021 18:03:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/982">@florian</a>,</p>
<p dir="auto">You are going to want to make sure that you are on the latest version of FusionAuth (1.29.1), as some versions may not display this option (this was a recent bug fix)</p>
<p dir="auto">Located under <code>Applications &gt; OAuth &gt; Toggle</code></p>
<p dir="auto">A screenshot is attached.<img src="/community/forum/assets/uploads/files/1628013777079-screen-shot-2021-08-03-at-11.50.53-am-resized.png" alt="Screen Shot 2021-08-03 at 11.50.53 AM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hope that helps!</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3465</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3465</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 03 Aug 2021 18:03:41 GMT</pubDate></item></channel></rss>
