<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Text on the Google login popup when using Google as an IdP]]></title><description><![CDATA[<p dir="auto">When Google is configured as an IdP, the popup screen tells the user to <code>Choose an account to continue to fusionauth.io</code>.</p>
<p dir="auto">Is there a way to change that hostname ("<a href="http://fusionauth.io" rel="nofollow ugc">fusionauth.io</a>") to one of our domains?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/118/text-on-the-google-login-popup-when-using-google-as-an-idp</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 10:23:22 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/118.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 May 2020 21:12:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Text on the Google login popup when using Google as an IdP on Tue, 26 May 2020 21:14:17 GMT]]></title><description><![CDATA[<p dir="auto">As far as I know it is not possible, I believe Google builds that text based upon the <code>redirect_uri</code>. I would assume you'd only see the <a href="http://fusionauth.io" rel="nofollow ugc">fusionauth.io</a> domain listed if you're using our hosted URL. If you are using an enterprise plan with a custom domain (<a href="http://login.example.com" rel="nofollow ugc">login.example.com</a>) you shouldn't see <a href="http://fusionauth.io" rel="nofollow ugc">fusionauth.io</a> mentioned.</p>
<p dir="auto">I know in the Google cloud console where you configure your credentials there is a customization option for the consent screen, but I do not know if that will modify this account chooser or not.</p>
]]></description><link>https://fusionauth.io/community/forum/post/262</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/262</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 26 May 2020 21:14:17 GMT</pubDate></item></channel></rss>
