<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider?]]></title><description><![CDATA[<p dir="auto">Received a notification from Google that they're discontinuing Google Sign-In JavaScript Platform Library for web (<a href="https://developers.googleblog.com/2021/08/gsi-jsweb-deprecation.html" rel="nofollow ugc">https://developers.googleblog.com/2021/08/gsi-jsweb-deprecation.html</a>). They provided us "a list of your client ID(s) that use the legacy Google Sign-In web solution" and the only item was the client id we set up for FusionAuth's Google identity provider.</p>
<p dir="auto">Will this affect the Google identity provider in FusionAuth, and if so, is it on the roadmap to be updated?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1208/does-deprecation-of-javascript-google-platform-library-affect-fusionauth-google-identity-provider</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 13:54:32 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1208.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Aug 2021 16:57:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Tue, 07 Jan 2025 11:55:19 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for share this information............</p>
]]></description><link>https://fusionauth.io/community/forum/post/7714</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7714</guid><dc:creator><![CDATA[miller]]></dc:creator><pubDate>Tue, 07 Jan 2025 11:55:19 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Tue, 19 Mar 2024 05:57:34 GMT]]></title><description><![CDATA[<p dir="auto">The deprecation of a JavaScript Google Platform Library may affect FusionAuth Google Identity Provider integration if FusionAuth relies on the deprecated library for its Google authentication functionality.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7137</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7137</guid><dc:creator><![CDATA[admin a]]></dc:creator><pubDate>Tue, 19 Mar 2024 05:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Mon, 18 Mar 2024 09:25:23 GMT]]></title><description><![CDATA[<p dir="auto">We're thankful for your contributions to our understanding!</p>
]]></description><link>https://fusionauth.io/community/forum/post/7135</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7135</guid><dc:creator><![CDATA[admin a]]></dc:creator><pubDate>Mon, 18 Mar 2024 09:25:23 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Fri, 03 Feb 2023 05:22:27 GMT]]></title><description><![CDATA[<p dir="auto">The deprecation of the JavaScript Google Platform Library may affect the use of FusionAuth as a Google Identity Provider, depending on how the library is integrated with FusionAuth.<br />
It is recommended to check with the FusionAuth support team or documentation to determine if the deprecation will have any impact on your implementation and what, if any, actions need to be taken<a href="https://www.landstaronline.org/" rel="nofollow ugc">.</a><br />
In general, it's a good practice to regularly review and update any dependencies and libraries used in your application to ensure compatibility and security.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5897</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5897</guid><dc:creator><![CDATA[ramyar.jahani14256]]></dc:creator><pubDate>Fri, 03 Feb 2023 05:22:27 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Sun, 29 Jan 2023 20:58:20 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/212">@harish_reddy</a> !</p>
<p dir="auto">Per <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1939#issuecomment-1403875187" rel="nofollow ugc">this comment</a>, this is slated to be fixed under <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1894" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1894</a> .</p>
<p dir="auto">This is planned for 1.43.0, which is the next release.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5874</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5874</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sun, 29 Jan 2023 20:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Wed, 25 Jan 2023 11:29:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a></p>
<p dir="auto">I can confirm fusionauth is using deprecated javascript library.</p>
<p dir="auto">I wrote my analysis here <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1939" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1939</a></p>
<p dir="auto">Can you please release a patch for updating the code.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5849</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5849</guid><dc:creator><![CDATA[harish_reddy]]></dc:creator><pubDate>Wed, 25 Jan 2023 11:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider? on Thu, 12 Aug 2021 21:51:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/348">@pclark</a> said in <a href="/community/forum/post/3524">Does deprecation of JavaScript Google Platform Library affect FusionAuth Google Identity Provider?</a>:</p>
<p dir="auto">Received a notification from Google that they're discontinuing Google Sign-In JavaScript Platform Library for web (<a href="https://developers.googleblog.com/2021/08/gsi-jsweb-deprecation.html" rel="nofollow ugc">https://developers.googleblog.com/2021/08/gsi-jsweb-deprecation.html</a>). They provided us "a list of your client ID(s) that use the legacy Google Sign-In web solution" and the only item was the client id we set up for FusionAuth's Google identity provider.<br />
<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/348">@pclark</a>,</p>
<p dir="auto">I have raised this issue on Github to review if we are in fact using this JS library and modify if we are.  Thanks for the information.</p>
<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-issues/issues/1347" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1347</a></p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3526</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3526</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 12 Aug 2021 21:51:55 GMT</pubDate></item></channel></rss>
