<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Searching for user by email address returns a lot more results than I&#x27;d expect]]></title><description><![CDATA[<p dir="auto">I'm using the Elasticsearch search engine and when I search in the admin UI for a particular email, like <code>user@example.com</code>, I get a lot of responses back. I'm surprised, I'd expect to only get back the user with that email address.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1247/searching-for-user-by-email-address-returns-a-lot-more-results-than-i-d-expect</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 09:04:39 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1247.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Aug 2021 21:32:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Searching for user by email address returns a lot more results than I&#x27;d expect on Tue, 31 Aug 2021 21:33:59 GMT]]></title><description><![CDATA[<p dir="auto">Hiya.</p>
<p dir="auto">You can see the elasticsearch query if you expand <code>advanced</code> in the UI.</p>
<p dir="auto">Because of the way that we tokenize the search string, it is likely that a query like <code>user@example.com</code> will match more than just the user with the email address you are entering.</p>
<p dir="auto">If you want to match only the email address in the UI, the easiest way to do it is to preface the query with <code>email:</code>. So <code>email:user@example.com</code>.</p>
<p dir="auto">Hope that helps.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3626</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3626</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 31 Aug 2021 21:33:59 GMT</pubDate></item></channel></rss>
