<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;ve written a password encryption plugin I want to share. Where can I share it?]]></title><description><![CDATA[<p dir="auto">I've written a <a href="https://fusionauth.io/docs/v1/tech/plugins/writing-a-plugin" rel="nofollow ugc">plugin for a password encryption scheme</a> that FusionAuth doesn't currently support. Where can I share that?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/126/i-ve-written-a-password-encryption-plugin-i-want-to-share-where-can-i-share-it</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 14:07:23 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/126.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 May 2020 15:03:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;ve written a password encryption plugin I want to share. Where can I share it? on Thu, 17 Dec 2020 19:48:45 GMT]]></title><description><![CDATA[<p dir="auto">In case it helps anyone, a version of the <a href="https://github.com/dotnet/aspnetcore/blob/master/src/Identity/Extensions.Core/src/PasswordHasher.cs#L141" rel="nofollow ugc">ASP.NET Core Identity PasswordHasher HashPasswordV3</a></p>
<pre><code>package com.mycompany.fusionauth.plugins;
import javax.crypto.SecretKey;
import javax.crypto.SecretKeyFactory;
import javax.crypto.spec.PBEKeySpec;
import java.nio.charset.StandardCharsets;
import java.security.InvalidKeyException;
import java.security.NoSuchAlgorithmException;
import java.security.spec.InvalidKeySpecException;
import java.security.spec.KeySpec;
import java.util.Base64;
import io.fusionauth.plugin.spi.security.PasswordEncryptor;
* Example password hashing based on Asp.Net Core Identity PasswordHasher HashPasswordV3.
public class ExampleDotNetPBDKF2HMACSHA256PasswordEncryptor implements PasswordEncryptor {
  @Override
  public int defaultFactor() {
    return 10_000;
  @Override
  public String encrypt(String password, String salt, int factor) {
    if (factor &lt;= 0) {
      throw new IllegalArgumentException("Invalid factor value [" + factor + "]");
    SecretKeyFactory keyFactory;
    try {
      keyFactory = SecretKeyFactory.getInstance("PBKDF2WithHmacSHA256");
    } catch (NoSuchAlgorithmException e) {
      throw new IllegalStateException("No such algorithm [PBKDF2WithHmacSHA256]");
	int keyLength = 32; // numBytesRequested
	byte[] saltBytes = Base64.getDecoder().decode(salt); // assumes Base64 encoded salt. saltSize: 16 bytes
    KeySpec keySpec = new PBEKeySpec(password.toCharArray(), saltBytes, factor, keyLength * 8);
    SecretKey secret;
    try {
      secret = keyFactory.generateSecret(keySpec); // subkey
    } catch (InvalidKeySpecException e) {
      throw new IllegalArgumentException("Could not generate secret key for algorithm [PBKDF2WithHmacSHA256]");
	byte[] outputBytes = new byte[13 + saltBytes.length + secret.getEncoded().length];
	outputBytes[0] = 0x01; // format marker
	WriteNetworkByteOrder(outputBytes, 1, 1);
	WriteNetworkByteOrder(outputBytes, 5, factor);
	WriteNetworkByteOrder(outputBytes, 9, saltBytes.length);
	System.arraycopy(saltBytes, 0, outputBytes, 13, saltBytes.length);
	System.arraycopy(secret.getEncoded(), 0, outputBytes, 13 + saltBytes.length, secret.getEncoded().length);
	return new String(Base64.getEncoder().encode(outputBytes));
  private static void WriteNetworkByteOrder(byte[] buffer, int offset, int value)
	buffer[offset + 0] = (byte)(value &gt;&gt; 24);
	buffer[offset + 1] = (byte)(value &gt;&gt; 16);
	buffer[offset + 2] = (byte)(value &gt;&gt; 8);
	buffer[offset + 3] = (byte)(value &gt;&gt; 0);
import org.testng.annotations.DataProvider;
import org.testng.annotations.Test;
import static org.testng.Assert.assertEquals;
public class ExampleDotNetPBDKF2HMACSHA256PasswordEncryptorTest {
  @Test(dataProvider = "hashes")
  public void encrypt(String password, String salt, String hash) {
    ExampleDotNetPBDKF2HMACSHA256PasswordEncryptor encryptor = new ExampleDotNetPBDKF2HMACSHA256PasswordEncryptor();
    assertEquals(encryptor.encrypt(password, salt, 10_000), hash);
  @DataProvider(name = "hashes")
  public Object[][] hashes() {
    return new Object[][]{
        {"MyExamplePassword", "CVsv6SwPJr7WDrVvAb+7aw==", "AQAAAAEAACcQAAAAEAlbL+ksDya+1g61bwG/u2ssOcnQU6Q2xo9tmijJv0zM2GsxeOl04NSpXRsAveBBag=="},
]]></description><link>https://fusionauth.io/community/forum/post/1990</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1990</guid><dc:creator><![CDATA[pclark]]></dc:creator><pubDate>Thu, 17 Dec 2020 19:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve written a password encryption plugin I want to share. Where can I share it? on Thu, 28 May 2020 17:27:12 GMT]]></title><description><![CDATA[<p dir="auto">There's a <a href="https://github.com/FusionAuth/fusionauth-example-password-encryptor/" rel="nofollow ugc">skeleton github repo</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/287</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/287</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 28 May 2020 17:27:12 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve written a password encryption plugin I want to share. Where can I share it? on Thu, 28 May 2020 15:04:24 GMT]]></title><description><![CDATA[<p dir="auto">Please go ahead and add it to this topic.</p>
]]></description><link>https://fusionauth.io/community/forum/post/286</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/286</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 28 May 2020 15:04:24 GMT</pubDate></item></channel></rss>
