<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[startup Self-Service Registration?]]></title><description><![CDATA[<p dir="auto">Joshua, I have been trying for over a year to get an answer to why my passwordless login is failing. I do have it working in another part of my application so I know it works.</p>
<p dir="auto">I also know that fusionAuth is interested in signing up paid users and i am aware of my Linkedin (which i don't really use for security reasons) being perused by some of your marketing people. I just don't know how you get signups without customer success?</p>
<p dir="auto">I am ready to launch and need to get the passwordless working. Is there a consulting arraignment I could set up to fix this one little issue? You must know an ex-FA employee who would like to make a few extra $?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1267/startup-self-service-registration</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 06:58:24 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1267.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Sep 2021 11:38:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to startup Self-Service Registration? on Wed, 22 Sep 2021 12:02:35 GMT]]></title><description><![CDATA[<p dir="auto">Hey Dan. It has been a long time! I just can't get past the passwordless problem I have with fusionAuth. Your help has been stellar but I really need to hire someone to get me over the "hump". Seems like there are not too many people out there that have a working knowledge of FA. I have tried to find one! Can't hire help and can't get community help leaves me with no options.</p>
<p dir="auto">I took a look at <a href="https://fusionauth.io/learn/expert-advice/authentication/webapp/oauth-authorization-code-grant-sessions/" rel="nofollow ugc">https://fusionauth.io/learn/expert-advice/authentication/webapp/oauth-authorization-code-grant-sessions/</a> and will try to switch over to using this method since it seems well documented. I will probably need to find someone to update the themes if I get it going. Good luck on that!</p>
<p dir="auto">I really like the diagram which shows the message flows in it. Is there a document, just like oauth-authorization-code-grant-sessions but for passwordless? That diagram, but for passwordless, would definately help.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3728</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3728</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Wed, 22 Sep 2021 12:02:35 GMT</pubDate></item><item><title><![CDATA[Reply to startup Self-Service Registration? on Tue, 21 Sep 2021 02:11:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a></p>
<p dir="auto">That code is javascript. You should be able to use a function like <a href="https://www.php.net/manual/en/function.base64-encode.php" rel="nofollow ugc">https://www.php.net/manual/en/function.base64-encode.php</a> to do the same.</p>
<p dir="auto">We don't have any documentation on moving to Auth0. Here's info on import users to Auth0: <a href="https://auth0.com/docs/users/import-and-export-users" rel="nofollow ugc">https://auth0.com/docs/users/import-and-export-users</a> but I haven't tested that. Looks like you need to build a JSON file to import users: <a href="https://auth0.com/docs/users/import-and-export-users/bulk-user-import-database-schema-and-examples" rel="nofollow ugc">https://auth0.com/docs/users/import-and-export-users/bulk-user-import-database-schema-and-examples</a></p>
<p dir="auto">You'll probably want to read directly from the FusionAuth database.</p>
<p dir="auto">Not sure about the other configuration.</p>
<p dir="auto">Sorry to hear FusionAuth didn't meet your needs, but I hope your app is a wild success!</p>
]]></description><link>https://fusionauth.io/community/forum/post/3718</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3718</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 21 Sep 2021 02:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to startup Self-Service Registration? on Sun, 19 Sep 2021 05:52:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I read the Modern Guide to Oauth yesterday. In it I see that this  code is being used to condition the URL prior to sending.</p>
<pre><code>function base64URLEncode(str) {
  return str.toString('base64')
    .replace(/\+/g, '-')
    .replace(/\//g, '_')
    .replace(/=/g, '');
<p dir="auto">I don't know what language this is in. Where can I find a php version?</p>
<p dir="auto">I also saw a document up here on porting from fusionAuth to auth0. I am considering going the other way. Do you guys have a document describing how to do that?</p>
]]></description><link>https://fusionauth.io/community/forum/post/3712</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3712</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Sun, 19 Sep 2021 05:52:55 GMT</pubDate></item><item><title><![CDATA[Reply to startup Self-Service Registration? on Fri, 17 Sep 2021 21:54:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/279">@richb201</a></p>
<p dir="auto">Thanks for the update!  I definitely understand the struggle of getting an integration to work the way that you expect it to.  I see that my colleagues have (re)posted your help requested posts; hopefully, someone from the community can lend a helping hand!</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3709</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3709</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Fri, 17 Sep 2021 21:54:25 GMT</pubDate></item></channel></rss>
