<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[setting up a staging server]]></title><description><![CDATA[<p dir="auto">I have set up a staging server called <a href="http://stage.researchstudyonline.com" rel="nofollow ugc">stage.researchstudyonline.com</a>. It is running parallel to my real server <a href="http://researchstudyonone.com" rel="nofollow ugc">researchstudyonone.com</a>. So they are two different domains and thus use two different fusionAuth servers. They both use the same mysql RDS database.</p>
<p dir="auto">I can log into the original one fine. But my userid/password doesn't work on <a href="http://stage.researchstudyonline.com:9011" rel="nofollow ugc">http://stage.researchstudyonline.com:9011</a>. How can fix this? Must I create a separate database for the staging server?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1310/setting-up-a-staging-server</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 21:18:55 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1310.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Oct 2021 12:57:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to setting up a staging server on Tue, 12 Oct 2021 17:56:18 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I set up two databases now instead of just one and having both production and staging share it. But I find when I go into the FA control panel on staging and change things such as paths it changes the paths for both the staging and the production servers.</p>
<p dir="auto">Where do I specify (for each server) what database should be used?</p>
]]></description><link>https://fusionauth.io/community/forum/post/3805</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3805</guid><dc:creator><![CDATA[richb201]]></dc:creator><pubDate>Tue, 12 Oct 2021 17:56:18 GMT</pubDate></item><item><title><![CDATA[Reply to setting up a staging server on Tue, 12 Oct 2021 05:52:46 GMT]]></title><description><![CDATA[<p dir="auto">I don't know the FA internals but I'm pretty sure that you indeed need to create a DB for the staging environment. I have a similar setup with prod and staging FA instances but with separate databases for both. Works flawlessly <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/3803</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3803</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Tue, 12 Oct 2021 05:52:46 GMT</pubDate></item></channel></rss>
