<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error after updating the password]]></title><description><![CDATA[<p dir="auto">Hello, I have an issue after updating the password. After I update the password, fusionauth redirects from "myurl/password/change/idUser" theme to "myurl/password/change/change". It shows an error 500 and it doesn't take the change password complete theme.</p>
<p dir="auto">I attach an image<br />
<img src="/community/forum/assets/uploads/files/1634326507129-captura-de-pantalla-2021-10-15-a-la-s-2.34.58-p.m..png" alt="Captura de Pantalla 2021-10-15 a la(s) 2.34.58 p. m..png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I would appreciate your help</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1317/error-after-updating-the-password</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 13:30:29 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1317.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Oct 2021 19:37:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error after updating the password on Wed, 12 Jan 2022 21:53:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a></p>
<p dir="auto">Glad that you are able to figure it out.  I am not sure if that qualifies as a bug, but definitely something to be aware of and might be worth calling out in our documentation.</p>
<p dir="auto">I believe that you should have email templates after a kickstart (at least the default ones).  I can do some more testing to see if that same thing happens to me when I kickstart.</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4188</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4188</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Wed, 12 Jan 2022 21:53:23 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Wed, 12 Jan 2022 08:31:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a> I've tried with the FA 1.32.1 and I think I've found the source of the problem.<br />
Turns out I had my Forgot Password Email template a bit old (AFAIR based on the template from 1.27.2).</p>
<p dir="auto">Because of this, the URL to reset the password (in the email template) was generated like:</p>
<pre><code>https://#{FA_DOMAIN}/password/change/${changePasswordId}?tenantId=${user.tenantId}
<p dir="auto">In the newer versions of FA it was changed to:</p>
<pre><code>[#assign url = "https://#{FA_DOMAIN}/password/change/${changePasswordId}?client_id=${(application.oauthConfiguration.clientId)!''}&amp;tenantId=${user.tenantId}" /]
[#list state!{} as key, value][#if key != "tenantId" &amp;&amp; key != "client_id" &amp;&amp; value??][#assign url = url + "&amp;" + key?url + "=" + value?url/][/#if][/#list]
${url}
<p dir="auto">The point is that with the new version we have extra parameters in the URL like <strong>client_id</strong>, <strong>redirect_uri</strong> and a few others. Everything works properly with the new syntax. If these new parameters are missing (I suppose the main issue is lack of the <strong>client_id</strong>) FA triggers error 500 after password reset (for the users that are not registered in the application that generated the password reset e-mail).</p>
<p dir="auto">The most recent version of FA triggers a more detailed error message in the log than the previous one and this helped me a bit to track the problem:</p>
<pre><code>2022-01-11 4:19:10.373 PM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
java.lang.NullPointerException: Cannot read field "oauthConfiguration" because "this.application" is null
   at io.fusionauth.app.action.oauth2.BaseOAuthAction.handleInteractiveLoginResponse(BaseOAuthAction.java:548)
   at io.fusionauth.app.action.oauth2.BaseOAuthAction.callLogin(BaseOAuthAction.java:447)
   at io.fusionauth.app.action.password.ChangeAction.post(ChangeAction.java:121)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
   at java.base/java.lang.reflect.Method.invoke(Method.java:568)
   at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:414)
   at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:79)
   at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:62)
   at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:51)
   at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:47)
   at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:60)
   at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:50)
   at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:52)
   at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:57)
   at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:102)
   at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:58)
   at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:44)
   at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:126)
   at org.primeframework.mvc.workflow.StaticResourceWorkflow.perform(StaticResourceWorkflow.java:97)
   at org.primeframework.mvc.parameter.RequestBodyWorkflow.perform(RequestBodyWorkflow.java:91)
   at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:64)
   at io.fusionauth.app.primeframework.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:51)
   at io.fusionauth.app.primeframework.FusionAuthMVCWorkflow.perform(FusionAuthMVCWorkflow.java:86)
   at org.primeframework.mvc.workflow.DefaultWorkflowChain.continueWorkflow(DefaultWorkflowChain.java:44)
   at org.primeframework.mvc.servlet.FilterWorkflowChain.continueWorkflow(FilterWorkflowChain.java:50)
   at org.primeframework.mvc.servlet.PrimeFilter.doFilter(PrimeFilter.java:78)
   at com.inversoft.maintenance.servlet.MaintenanceModePrimeFilter.doFilter(MaintenanceModePrimeFilter.java:63)
   at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
   at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
   at com.inversoft.servlet.UTF8Filter.doFilter(UTF8Filter.java:27)
   at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:196)
   at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
   at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:542)
   at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
   at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
   at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
   at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:364)
   at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:624)
   at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
   at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
   at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1650)
   at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
   at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
   at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
   at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
   at java.base/java.lang.Thread.run(Thread.java:833)
<p dir="auto">I'm not sure if this can be considered a bug in FA? What do you think?</p>
<p dir="auto">BTW. Is this normal that if the kickstart file is used then no default email templates are generated at all?</p>
]]></description><link>https://fusionauth.io/community/forum/post/4185</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4185</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Wed, 12 Jan 2022 08:31:32 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 10 Jan 2022 20:45:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a>,</p>
<p dir="auto">Yes, if you had this that might be helpful.  I tried again, and still worked for me.</p>
<p dir="auto">Also, you can log a bug report if you feel this is appropriate</p>
<li><a href="https://github.com/FusionAuth/fusionauth-issues/issues/new/choose" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/new/choose</a></li>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4176</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4176</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Mon, 10 Jan 2022 20:45:05 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 10 Jan 2022 19:22:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a> yes, I still have this issue on a few instances of FA while trying to change password for the user that is not registered in the specific application. If you're not able to reproduce this I can try to create a kickstart script to recreate the problem</p>
]]></description><link>https://fusionauth.io/community/forum/post/4173</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4173</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Mon, 10 Jan 2022 19:22:23 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 10 Jan 2022 17:49:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1174">@developers</a> Is this still an open issue for you?</p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4171</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4171</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Mon, 10 Jan 2022 17:49:05 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 13 Dec 2021 05:52:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> thanks for replying. I checked and seems [singleCase]user.password already there in my custom theme.<img src="/community/forum/assets/uploads/files/1639374731570-theme-message.png" alt="theme-message.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/4051</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4051</guid><dc:creator><![CDATA[developers]]></dc:creator><pubDate>Mon, 13 Dec 2021 05:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Sun, 12 Dec 2021 20:41:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1174">@developers</a> in your case the error message is pretty self-explanatory. The problem is just a lack of &lsqb;&lsqb;singleCase]user.password] message in your theme. Just add this message to your theme and it should work <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/4050</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4050</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Sun, 12 Dec 2021 20:41:30 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Sun, 12 Dec 2021 08:31:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a>  Unfortunately, I have similar issue while updating the password through Self Service Portal. It displays 500 Internal Server Error only if new password is not as per application specific password validation rules/constraints. It works fine if updated as per validation rules. As per correct flow , it should display field errors for validations instead redirecting to 500 Internal Server Error.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1639297528671-internal-server-error.png" alt="Internal Server Error.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1639297790806-password-update-ss-portal.png" alt="Password update SS portal.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">For reference, logs are<br />
<img src="/community/forum/assets/uploads/files/1639297692505-logs-resized.png" alt="Logs.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/4049</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4049</guid><dc:creator><![CDATA[developers]]></dc:creator><pubDate>Sun, 12 Dec 2021 08:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Fri, 10 Dec 2021 18:14:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a></p>
<p dir="auto">This was not immediately reproducible on my machine.  I am going to try and few more things and will let you know.</p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4046</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4046</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Fri, 10 Dec 2021 18:14:12 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Thu, 09 Dec 2021 17:30:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a>,</p>
<p dir="auto">Thanks for the reminder - this is on my list to review this week and log a bug report if needed.</p>
<p dir="auto">Thanks<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4043</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4043</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:30:02 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Thu, 09 Dec 2021 13:42:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a> any chance you had some time to look at this? Is this reproducible on your end?</p>
]]></description><link>https://fusionauth.io/community/forum/post/4041</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4041</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Thu, 09 Dec 2021 13:42:45 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Wed, 24 Nov 2021 14:46:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a> I think I've found the pattern to reproduce this issue.<br />
Basically, it fails if the user I want to reset the password for is not registered in the application whose client_id is used during password reset flow. It works for the application where the user has a valid registration.</p>
<p dir="auto">To reproduce:</p>
<li>Create new tenant: <strong>Tenant1</strong></li>
<li>Create two Applications for <strong>Tenant1</strong>: <strong>application1</strong> and <strong>application2</strong> using <a href="https://example.com" rel="nofollow ugc">https://example.com</a> as redirect_uri</li>
<li>Create user: <strong>user1</strong> for <strong>Tenant1</strong></li>
<li>Create registration for <strong>user1</strong> in <strong>application1</strong></li>
<li>Open the authorize URL for <strong>application2</strong> like:<br />
https://&lt;<strong>FUSIONAUTH_URL</strong>&gt;/oauth2/authorize?client_id=&lt;<strong>CLIENT_ID_OF_APPLICATION2</strong>&gt;&amp;scope=openid%20offline_access&amp;response_type=code&amp;redirect_uri=https%3A%2F%<a href="http://2Fexample.com" rel="nofollow ugc">2Fexample.com</a>&amp;tenantId=&lt;<strong>TENANT_ID</strong>&gt;</li>
<li>Click Forgot your password</li>
<li>Check you e-mail and click the password reset link</li>
<li>Try to change the password<br />
It should fail at this point.</li>
<p dir="auto">You can now check the same for application1 (with the user registration) to see if it works.</p>
<p dir="auto">I'm very curious if you can reproduce this too.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3991</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3991</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Wed, 24 Nov 2021 14:46:52 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Thu, 18 Nov 2021 20:58:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a></p>
<p dir="auto">Hmmm. As I read our conversation, there are no simple reproduction steps that you are able to determine?  This is happening to just random users?<br />
Still reviewing, but let me know if you have any other thoughts on this.</p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3960</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3960</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Thu, 18 Nov 2021 20:58:27 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Tue, 16 Nov 2021 08:22:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/645">@joshua</a> I think that yes, these users were imported and they're using salted-pbkdf2-hmac-sha256, but their imported passwords are useable so I don't think these are hashed incorrectly.</p>
<p dir="auto">We have themed pages but I've also tried with the "Default" theme and the issue occurred as well. It is worth noting that even though I get an error from FA, the password is changed and the user is logged in automatically after the password change form is submitted. Seems that the password change procedure works but the problem is a bit later.</p>
<p dir="auto">Using the API it works properly:</p>
<pre><code>In [42]: res = client.forgot_password({"loginId": 'someuser@somedomain.com'})
In [43]: change_password_id = res.success_response["changePasswordId"]
In [44]: res2 = client.change_password(change_password_id, {'password': 'somepass2'})
In [45]: res2.was_successful()
Out[45]: True
]]></description><link>https://fusionauth.io/community/forum/post/3949</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3949</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Tue, 16 Nov 2021 08:22:10 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 15 Nov 2021 21:06:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a> said in <a href="/community/forum/post/3922">Error after updating the password</a>:</p>
<p dir="auto">No MFA is in use. Users were created a long time ago.</p>
<p dir="auto">In the past, we have seen issues where imported users with improperly imported password hashes had trouble resetting their passwords.  Are these users imported?  Are they using a standard password encryptor/hash (<code>Salted PBKDF2 with SHA-256</code> for instance)?</p>
<p dir="auto">It sounds like you are using the Themed pages to change the password.  If you repeat the same actions that caused your previous failure, but this time with the API, do you get the same result?</p>
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/3948</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3948</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Mon, 15 Nov 2021 21:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 08 Nov 2021 16:34:45 GMT]]></title><description><![CDATA[<p dir="auto">Sorry for missing these in my previous post.</p>
<p dir="auto">The issue occurs in both environments: local is a single docker instance and the server environment uses two FA nodes.</p>
<p dir="auto">Database is PostgreSQL (9.6 in docker and 11 on the server - managed Postgres on DigitalOcean) + Elasticsearch.</p>
<p dir="auto">No MFA is in use. Users were created long time ago. As I said previously, it doesn't happen all the time, even for the same users. For example, I tried to change the password to 'password123' and it was impossible but when I tried another password like 'someotherpass.123' it worked. Then, trying to change the password again to password123 fails. In the same time, I was able to use 'password123' to reset password for some other user.  (note: sample password provided above are not real ones I've used).</p>
]]></description><link>https://fusionauth.io/community/forum/post/3922</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3922</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Mon, 08 Nov 2021 16:34:45 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Mon, 08 Nov 2021 16:23:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/56">@maciej-wisniowski</a></p>
<p dir="auto">Thanks! This is helpful and including the stack trace is great.</p>
<p dir="auto">Can you provide more details about your setup to aid in reproducing the bug?</p>
<li>Can you see this locally or only in prod?</li>
<li>How many servers are you running for this instance (1, 2, etc)?</li>
<li>What database and version are you using?</li>
<li>Any info in the event log?</li>
<li>Does this happen for all users or only users in a certain state (with MFA on, newly registered, etc)?</li>
<p dir="auto">Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/post/3920</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3920</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 08 Nov 2021 16:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Fri, 05 Nov 2021 13:04:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> unfortunately it seems that I've encountered same, or similar error with the latest FA 1.30.2.<br />
This happened to us on two separate FA instances (self hosted).</p>
<p dir="auto">How to reproduce the issue is not very clear to me because it doesn't appear all the time but what I did is:</p>
<li>Start the password reset flow (eg. clicking the Forgot password link on the login screen)</li>
<li>Open the password change form using the link from the e-mail</li>
<li>Enter a new password and submit the form</li>
<li>The error appears</li>
<p dir="auto">As I said, it doesn't happen all the time but I have a feeling it might be somehow related to using the same password as it was before the password reset.</p>
<p dir="auto">I tried:</p>
<li>disabling Reactor (one of the affected FA instances had it enabled)</li>
<li>disabling login.successful webhook we're using</li>
<li>disabling custom theme we have</li>
<p dir="auto">Nothing helped</p>
<p dir="auto">The FusionAuth log shows the following error:</p>
<pre><code>2021-11-05 1:36:38.364 PM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
java.lang.NullPointerException: null
	at io.fusionauth.app.action.oauth2.BaseOAuthAction.handleInteractiveLoginResponse(BaseOAuthAction.java:545)
	at io.fusionauth.app.action.oauth2.BaseOAuthAction.callLogin(BaseOAuthAction.java:446)
	at io.fusionauth.app.action.password.ChangeAction.post(ChangeAction.java:117)
	at jdk.internal.reflect.GeneratedMethodAccessor286.invoke(Unknown Source)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at io.fusionauth.app.primeframework.CORSFilter.doFilter(CORSFilter.java:237)
	at io.fusionauth.app.primeframework.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:49)
	at java.base/java.lang.Thread.run(Thread.java:832)
]]></description><link>https://fusionauth.io/community/forum/post/3915</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3915</guid><dc:creator><![CDATA[maciej.wisniowski]]></dc:creator><pubDate>Fri, 05 Nov 2021 13:04:19 GMT</pubDate></item><item><title><![CDATA[Reply to Error after updating the password on Sat, 16 Oct 2021 15:53:34 GMT]]></title><description><![CDATA[<p dir="auto">From other communication, you are running 1.19.7. My suggestions are:</p>
<li>See if the bug is fixed in a more recent version. You could always test by standing up a copy of your product database, upgrading it, and then seeing if the issue occurs. This would provide more info for us without impacting your production system.</li>
<li>Look through the detailed release notes to see if we have fixed this bug, upgrade to that specific version: <a href="https://fusionauth.io/docs/v1/tech/release-notes/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/release-notes/</a></li>
<li>If you have a paid support plan, open a ticket: <a href="https://account.fusionauth.io/account/support/" rel="nofollow ugc">https://account.fusionauth.io/account/support/</a></li>
<p dir="auto">We're a small team and try to support everyone to the best of our ability, but supporting versions 10 minor releases behind the current release without a paid support plan is, as I'm sure you can understand, hard for us to do. Please help us by testing it out on the latest version or pursue one of the other options listed above.</p>
<p dir="auto">Just as an FYI, it is extremely unlikely we will backport a fix to 1.19 (we almost never do that for functionality bugs), so if we found a bug and fixed it, you'd likely have to upgrade.</p>
]]></description><link>https://fusionauth.io/community/forum/post/3826</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3826</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sat, 16 Oct 2021 15:53:34 GMT</pubDate></item></channel></rss>
