<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Registering as an SP in InCommon Federation]]></title><description><![CDATA[<p dir="auto">Is it possible to integrate as an SP using FusionAuth with IdPs that are in the InCommon Federation?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/143/registering-as-an-sp-in-incommon-federation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 16:12:03 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/143.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Jun 2020 17:25:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Registering as an SP in InCommon Federation on Fri, 05 Jun 2020 01:13:45 GMT]]></title><description><![CDATA[<p dir="auto">Looks like you added an issue: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/668" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/668</a></p>
<p dir="auto">Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/post/341</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/341</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 05 Jun 2020 01:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to Registering as an SP in InCommon Federation on Thu, 04 Jun 2020 14:22:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for experimenting. Is this an issue with FusionAuth or is this an issue with InCommon or some combination? Can you point me to any documentation that would help me learn more?</p>
<p dir="auto">If there is a specific behavior that FusionAuth needs to implement to work with InCommon, we'd love to hear about it. Please add more detail here or file an issue on our GitHub repo: <a href="https://github.com/fusionauth/fusionauth-issues/issues" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/338</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/338</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 04 Jun 2020 14:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Registering as an SP in InCommon Federation on Thu, 04 Jun 2020 13:55:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Thanks for the fast reply.  I am actively experimenting with FusionAuth.  I am impressed with it and was able to integrate with a SAML IdP easily.</p>
<p dir="auto">The InCommon Federation is a collection of SAML metadata between trusted partners.  What I have found is that each IdP added to FusionAuth generates it's own entityId. There is no way for one FusionAuth SP entityId to be registered with InCommon that multiple IdPs can use.</p>
]]></description><link>https://fusionauth.io/community/forum/post/337</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/337</guid><dc:creator><![CDATA[jhorton]]></dc:creator><pubDate>Thu, 04 Jun 2020 13:55:13 GMT</pubDate></item><item><title><![CDATA[Reply to Registering as an SP in InCommon Federation on Wed, 03 Jun 2020 19:44:29 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">I'm not aware of this configuration. However, many FusionAuth folks use the software without ever talking to us, so I'm not aware that this would not work either.</p>
<p dir="auto">I'd suggest downloading and giving it a try. From a brief web search, it looks like In Common doesn't work with OIDC just yet (I saw some draft specs). But FusionAuth also works with SAML and it looks like In Common supports that.</p>
<p dir="auto">Useful links: <a href="https://spaces.at.internet2.edu/display/federation/Federation+references" rel="nofollow ugc">https://spaces.at.internet2.edu/display/federation/Federation+references</a></p>
<p dir="auto">Setting up FA as a SAML SP: <a href="https://fusionauth.io/docs/v1/tech/identity-providers/samlv2/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/samlv2/</a></p>
<p dir="auto">Lambdas to reconcile user attributes: <a href="https://fusionauth.io/docs/v1/tech/lambdas/samlv2-response-reconcile" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/samlv2-response-reconcile</a></p>
<p dir="auto">Hope this helps. If you have more specific questions, please let us know.</p>
]]></description><link>https://fusionauth.io/community/forum/post/334</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/334</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 03 Jun 2020 19:44:29 GMT</pubDate></item></channel></rss>
