<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FusionAuth flows assistance]]></title><description><![CDATA[<p dir="auto">Good morning.<br />
I'm wondering if FusionAuth solution can assist me in implementing following flows, can you please consult me in those questions ?</p>
<p dir="auto">First scenario is login / registration of user with login as phone and password + user can reset password using SMS.<br />
Second scenario is  login / registration of user with login as phone and password + MFA with SMS code + user can also reset password using SMS.<br />
Third one is passwordless auth using only phone with SMS code.</p>
<p dir="auto">And also can I use generic messenger with all these flows ?</p>
<p dir="auto">Thanks in advance and have a nice day</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1430/fusionauth-flows-assistance</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 11:37:46 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1430.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Dec 2021 08:05:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FusionAuth flows assistance on Tue, 04 Jan 2022 00:26:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1285">@oleksiikraieviy</a></p>
<p dir="auto">The forum is a great place to get unstuck and ask questions - so thanks for the feedback! The scenarios you have listed here could have a number of different implementation considerations depending on context.</p>
<p dir="auto">One place to start looking would be our documentation.</p>
<p dir="auto">We have documentation around MFA below:</p>
<li><a href="https://fusionauth.io/docs/v1/tech/account-management/two-factor-sms/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/account-management/two-factor-sms/</a></li>
<p dir="auto">As well as documentation around passwordless below:</p>
<li><a href="https://fusionauth.io/docs/v1/tech/guides/passwordless/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/guides/passwordless/</a></li>
<p dir="auto">Finally, we have documentation around messengers below:</p>
<li><a href="https://fusionauth.io/docs/v1/tech/messengers/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/messengers/</a></li>
<p dir="auto">Some of the flows you describe should technically be possible, but would likely require custom integration code on your end.</p>
<p dir="auto">user can reset password using SMS.<br />
<p dir="auto">For instance, as far as I am aware, these are not natively built into FusionAuth.  This would be a custom integration.</p>
<p dir="auto">Generic messengers are very extensible and can integrate in a number of ways with the right integration/glue code.</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4129</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4129</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 04 Jan 2022 00:26:51 GMT</pubDate></item></channel></rss>
