<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FusionAuth incredibly slow on mac m1 in docker, even though I give it plenty of CPU&#x2F;RAM]]></title><description><![CDATA[<p dir="auto">Hey all,</p>
<p dir="auto">FusionAuth is incredibly slow on mac m1 in docker, even though I give it plenty of CPU/RAM.</p>
<p dir="auto">What gives?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1467/fusionauth-incredibly-slow-on-mac-m1-in-docker-even-though-i-give-it-plenty-of-cpu-ram</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 08:52:14 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1467.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Jan 2022 22:04:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FusionAuth incredibly slow on mac m1 in docker, even though I give it plenty of CPU&#x2F;RAM on Sat, 15 Jan 2022 22:08:54 GMT]]></title><description><![CDATA[<p dir="auto">There is a known issue with performance if you are running our intel based Docker image on an M1 or other ARM based system.</p>
<p dir="auto">We will be pushing out support for M1/ARM shortly..<br />
We have a test image out there if you want to try it - using this one should provide much better performance.<br />
<a href="https://hub.docker.com/layers/fusionauth/fusionauth-app/1.32.1_multi/images/sha256-da71d5be2bc849ef9d4e1205508fa34994973d75798a47cab9a8484ee2592ff7?context=explore" rel="nofollow ugc">https://hub.docker.com/layers/fusionauth/fusionauth-app/1.32.1_multi/images/sha256-da71d5be2bc849ef9d4e1205508fa34994973d75798a47cab9a8484ee2592ff7?context=explore</a></p>
<p dir="auto">is the latest current experimental version. Make sure you choose the arm64 based image.</p>
]]></description><link>https://fusionauth.io/community/forum/post/4201</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4201</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sat, 15 Jan 2022 22:08:54 GMT</pubDate></item></channel></rss>
