<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Want access to my docker logs]]></title><description><![CDATA[<p dir="auto">I want access to logs from my docker instances. FusionAuth doesn't write system logs to the filesystem for docker: <a href="https://fusionauth.io/docs/v1/tech/admin-guide/monitor#log-files" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/admin-guide/monitor#log-files</a></p>
<p dir="auto">What can I do?</p>
<p dir="auto"><em>This is pulled over from <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1614" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1614</a></em></p>
]]></description><link>https://fusionauth.io/community/forum/topic/1549/want-access-to-my-docker-logs</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 15:09:11 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1549.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Mar 2022 16:09:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Want access to my docker logs on Tue, 06 Sep 2022 18:10:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1891">@sullivan</a></p>
<p dir="auto">Thanks for the question.  The reason that you are not seeing anything in this view is you need to have a docker logger set up.  FusionAuth will write system logs to STDOUT.  This output must be picked up by a logger in Docker (which can then be reviewed).  By contrast, if you were running FusionAuth in a non-containerized environment, this view would show you current system logs.</p>
<li><a href="https://docs.docker.com/config/containers/logging/configure/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/configure/</a></li>
<p dir="auto">Hope this helps!</p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/5451</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5451</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Tue, 06 Sep 2022 18:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to Want access to my docker logs on Wed, 31 Aug 2022 14:15:06 GMT]]></title><description><![CDATA[<p dir="auto">This answer partially to the question. What about the admin UI access? I mean this:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1661955302732-ace4a2e5-7362-4749-ab41-ecbb8c234be1-image.png" alt="ace4a2e5-7362-4749-ab41-ecbb8c234be1-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/5433</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5433</guid><dc:creator><![CDATA[sullivan]]></dc:creator><pubDate>Wed, 31 Aug 2022 14:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to Want access to my docker logs on Tue, 01 Mar 2022 16:09:18 GMT]]></title><description><![CDATA[<p dir="auto">This is a docker issue. I'd suggest you set up a logging driver. From a brief look it seems like this is a runtime option.</p>
<p dir="auto">More details: <a href="https://docs.docker.com/config/containers/logging/configure/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/configure/</a> and <a href="https://docs.docker.com/config/containers/logging/" rel="nofollow ugc">https://docs.docker.com/config/containers/logging/</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/4422</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4422</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 01 Mar 2022 16:09:18 GMT</pubDate></item></channel></rss>
