<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pending Link strategy does not complete]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm currently trying to implement linkings between Identity Providers and FusionAuth accounts.<br />
This works pretty good and the whole connect/authorization workflow runs flawlesly. Though, when using the Pending Link strategy, the user does not get linked at the end (although he is logged in, etc.). However, if I use the Link-on-email strategy for example, the user gets linked without a problem.</p>
<p dir="auto">I got no logs and no errors, apart from this message from the Debug Event Log of the Identity Provider (Discord): <code>3/1/2022 04:11:04 PM GMT The link must now be completed using the Link API.</code><br />
Furthermore, the workflow redirects to the same page where it started, but it has additional parameter: <code>?code=XXX&amp;locale=en&amp;state=XXX&amp;userState=Authenticated</code>.</p>
<p dir="auto">Apart from that, I really have no clues about this problem. I know my information is rather meagre, so if you have any additional questions, just ask.</p>
<p dir="auto">Best regards</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1551/pending-link-strategy-does-not-complete</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 18:51:11 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1551.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Mar 2022 16:39:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pending Link strategy does not complete on Wed, 23 Mar 2022 22:48:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1181">@chrissmueller328</a>,</p>
<p dir="auto">You will want to review our linking strategies.  When this occurs, oftentimes, this is due to custom mapping needed (you can see this in our discord doc).</p>
<li><a href="https://fusionauth.io/docs/v1/tech/identity-providers/#linking-strategy-examples" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/#linking-strategy-examples</a></li>
<p dir="auto">The event log is another great place to look to see how your user is or is not being linked/created.</p>
<p dir="auto">You can also look at our doc for discord as an IDP</p>
<li><a href="https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/discord" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect/discord</a></li>
<p dir="auto">Hope this helps!<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4485</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4485</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Wed, 23 Mar 2022 22:48:47 GMT</pubDate></item></channel></rss>
