<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[multi_match query?]]></title><description><![CDATA[<p dir="auto">Is it possible to use the <code>multi_match</code> ElasticSearch query with the <code>/api/user/search</code> endpoint?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/159/multi_match-query</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 08:18:07 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/159.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jun 2020 17:20:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to multi_match query? on Wed, 26 Aug 2020 04:24:36 GMT]]></title><description><![CDATA[<p dir="auto">It looks like multi match (at least as of 2019) doesn't support wildcards:</p>
<p dir="auto">[a] <code>multimatch</code> query requires <code>match</code> queries as its internal queries. And a <code>match</code> query doesn't support wildcards.</p>
<p dir="auto"><a href="https://discuss.elastic.co/t/query-with-multimatch-and-wildcard/189962" rel="nofollow ugc">https://discuss.elastic.co/t/query-with-multimatch-and-wildcard/189962</a></p>
<p dir="auto">Can you try with a non wildcard query?</p>
]]></description><link>https://fusionauth.io/community/forum/post/967</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/967</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 26 Aug 2020 04:24:36 GMT</pubDate></item><item><title><![CDATA[Reply to multi_match query? on Wed, 26 Aug 2020 01:18:14 GMT]]></title><description><![CDATA[<p dir="auto">I tried to use <code>multi_match</code> in search-query without success. The following query does not find users? Any suggestions why?</p>
<pre><code>{
  "bool" : {
    "must" : [ {
      "multi_match" : {
        "query" : "*",
        "fields" : [ "firstName^3", "lastName^3", "email" ]
]]></description><link>https://fusionauth.io/community/forum/post/965</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/965</guid><dc:creator><![CDATA[uhon]]></dc:creator><pubDate>Wed, 26 Aug 2020 01:18:14 GMT</pubDate></item><item><title><![CDATA[Reply to multi_match query? on Mon, 15 Jun 2020 17:21:23 GMT]]></title><description><![CDATA[<p dir="auto">I believe so. When you use the <code>query</code> option, we are essentially passing that query object straight through.</p>
]]></description><link>https://fusionauth.io/community/forum/post/397</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/397</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 15 Jun 2020 17:21:23 GMT</pubDate></item></channel></rss>
