<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot login with login API?]]></title><description><![CDATA[<p dir="auto">I'm using SAML.</p>
<p dir="auto">After calling the login API from my website (<a href="http://www.example.com" rel="nofollow ugc">www.example.com</a>) and stored access_token and refresh_token cookies to fusionauth website (<a href="http://auth.example.com" rel="nofollow ugc">auth.example.com</a>), when user will be redirect to fusionauth page I see http cookie but fusionauth shows me login page as if I'm not logged in.</p>
<p dir="auto">I've tried to update the login instant value too.</p>
<p dir="auto">What am I doing wrong?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/16/cannot-login-with-login-api</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:39:16 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/16.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Apr 2020 16:50:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot login with login API? on Thu, 23 Apr 2020 16:51:13 GMT]]></title><description><![CDATA[<p dir="auto">If you are using the Login API (/api/login) - this does not create an SSO session.</p>
<p dir="auto">The FusionAuth Login pages do not currently use the access_token or refresh_token cookies for session management.</p>
<p dir="auto">If you want the SSO feature - you need to use the FusionAuth login pages. This is the strategy outlined in the 5 minute setup guide: <a href="https://fusionauth.io/docs/v1/tech/5-minute-setup-guide" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/5-minute-setup-guide</a></p>
<p dir="auto">We do have a feature open to switch to token based SSO so that this use case would work: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/358" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/358</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/33</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/33</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 23 Apr 2020 16:51:13 GMT</pubDate></item></channel></rss>
