<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Save user address and return address (postal_code, street, number...) in OAuth token]]></title><description><![CDATA[<p dir="auto">Hi everybody!</p>
<p dir="auto">I need return user address in OAuth token, and I find in documentation that is possible return address info.</p>
<p dir="auto">Follow the documentation<br />
<a href="https://fusionauth.io/learn/expert-advice/oauth/modern-guide-to-oauth#the-userinfo-endpoint" rel="nofollow ugc">https://fusionauth.io/learn/expert-advice/oauth/modern-guide-to-oauth#the-userinfo-endpoint</a></p>
<p dir="auto">On OAuth2 flow we call <em>/userinfo</em> end-point, so we couldn't return address.</p>
<p dir="auto">The authorize route on FusionAuth we set <code>scope</code> parameter to receive <code>address openid</code>, but not work.</p>
<p dir="auto">And I couldn't find where I can save the user address so that it is redeemed there in <em>/userinfo</em>.</p>
<p dir="auto">Can you help me?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://fusionauth.io/community/forum/topic/1727/save-user-address-and-return-address-postal_code-street-number-in-oauth-token</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 18:59:30 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/1727.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Apr 2022 21:37:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Save user address and return address (postal_code, street, number...) in OAuth token on Sun, 24 Apr 2022 21:30:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1583">@vinicius-alfonso</a> !</p>
<p dir="auto">As documented here: <a href="https://fusionauth.io/docs/v1/tech/oauth/endpoints#userinfo" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/oauth/endpoints#userinfo</a> we don't provide the address info, even if you pass the <code>address</code> scope.</p>
<p dir="auto">Per the OpenID spec, section 5.4, it appears that supporting the <code>address</code> scope is optional: <a href="https://openid.net/specs/openid-connect-core-1_0.html#ScopeClaims" rel="nofollow ugc">https://openid.net/specs/openid-connect-core-1_0.html#ScopeClaims</a></p>
<p dir="auto">If this is important to you, please file an issue here: <a href="https://github.com/fusionauth/fusionauth-issues/issues" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues</a> with details about the use case.</p>
<p dir="auto">We are guided by our customers and community when it comes to implementation of issues. Here's our general roadmap guidance: <a href="https://fusionauth.io/docs/v1/tech/core-concepts/roadmap" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/core-concepts/roadmap</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/5053</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5053</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sun, 24 Apr 2022 21:30:55 GMT</pubDate></item></channel></rss>
