<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What’s your recommendation on handling roles across multiple applications within a Tenant?]]></title><description><![CDATA[<p dir="auto">Would you recommend using Groups for that?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/176/what-s-your-recommendation-on-handling-roles-across-multiple-applications-within-a-tenant</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 13:35:24 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/176.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2020 18:44:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What’s your recommendation on handling roles across multiple applications within a Tenant? on Fri, 19 Jun 2020 18:44:29 GMT]]></title><description><![CDATA[<p dir="auto">Groups would be a good solution. The group just allows you to assign the roles to the group instead of the user - and then the group membership allows you to inherit those roles (assuming the user is registered for the application whose roles belong to the group).</p>
]]></description><link>https://fusionauth.io/community/forum/post/437</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/437</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 19 Jun 2020 18:44:29 GMT</pubDate></item></channel></rss>
