<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a way to get all the members of a particular group?]]></title><description><![CDATA[<p dir="auto">Anyone know if there is a way to GET all of the members of a particular group? Looking at <a href="https://fusionauth.io/docs/v1/tech/apis/groups#add-users-to-a-group" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/groups#add-users-to-a-group</a> I only see Create/Delete.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/183/is-there-a-way-to-get-all-the-members-of-a-particular-group</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 10:12:49 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/183.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jun 2020 22:38:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a way to get all the members of a particular group? on Mon, 22 Jun 2020 22:41:30 GMT]]></title><description><![CDATA[<p dir="auto">You need to use the <a href="https://fusionauth.io/docs/v1/tech/apis/users#search-for-users" rel="nofollow ugc">user search API</a> with an elastic search query string.</p>
<p dir="auto">Here's a curl example:</p>
<pre><code>API_KEY=....
GROUP_ID=f4a64b10-1cf6-4289-84c0-c3035f3b78bc
curl -H "Authorization: $API_KEY" 'http://localhost:9011/api/user/search/?queryString=memberships.groupId:'$GROUP_ID
<p dir="auto">If you are using the database search engine, you cannot find all the members of a group.</p>
]]></description><link>https://fusionauth.io/community/forum/post/460</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/460</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 22 Jun 2020 22:41:30 GMT</pubDate></item></channel></rss>
