<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a way to add the ForceAuthn property to a SAML V2 request?]]></title><description><![CDATA[<p dir="auto">We have Google SAML V2 as an Identity Provider and are running into a Google issue where if a user has multiple Google accounts (personal / work) and chooses the wrong account to authenticate to, the authentication rightfully fails, but Google seems to "cache" that the user selected the wrong account and no longer gives the user the option to choose what account they can sign into.</p>
<p dir="auto">Reading some forums online makes it seem that if you have <code>ForceAuthn="true</code> in the SAML v2 request, that it may give you the option to choose accounts each time an authentication request is made.</p>
<p dir="auto">Since Lambdas are used on the SAML response, is there any mechanism that FusionAuth has to be able to append properties to the SAML request?</p>
<p dir="auto">I am not entirely sure that this will fix the issue at hand, but a few forums seem to suggest it might remedy the issue.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2070/is-there-a-way-to-add-the-forceauthn-property-to-a-saml-v2-request</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 11:45:53 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2070.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 May 2022 18:50:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a way to add the ForceAuthn property to a SAML V2 request? on Fri, 27 May 2022 18:19:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/834">@jlinton</a></p>
<p dir="auto">Is it possible to leverage what is described in this post?</p>
<p dir="auto"><a href="https://fusionauth.io/community/forum/topic/663/force-google-account-selection-on-every-login">https://fusionauth.io/community/forum/topic/663/force-google-account-selection-on-every-login</a></p>
<p dir="auto">Also, how entrenched are you with SAML?</p>
]]></description><link>https://fusionauth.io/community/forum/post/5190</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5190</guid><dc:creator><![CDATA[jthughey]]></dc:creator><pubDate>Fri, 27 May 2022 18:19:54 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a way to add the ForceAuthn property to a SAML V2 request? on Fri, 27 May 2022 13:56:05 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for filing the issue, <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/834">@jlinton</a> !</p>
<p dir="auto">For anyone else following along, it's here: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1736" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1736</a></p>
<p dir="auto">Please feel free to upvote it or check the issue to determine if/when it is resolved.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5183</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5183</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 27 May 2022 13:56:05 GMT</pubDate></item><item><title><![CDATA[Reply to Is there a way to add the ForceAuthn property to a SAML V2 request? on Thu, 26 May 2022 14:27:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/834">@jlinton</a></p>
<p dir="auto">I do not believe there is any way to modify the SAML request beyond what is configurable in the identity provider: <a href="https://fusionauth.io/docs/v1/tech/identity-providers/samlv2/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/samlv2/</a></p>
<p dir="auto">Please feel free to file a github issue detailing the desire to be able to add <code>ForceAuthn</code>: <a href="https://github.com/fusionauth/fusionauth-issues/issues" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/5173</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5173</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 26 May 2022 14:27:33 GMT</pubDate></item></channel></rss>
