<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[404 &#x2F;api&#x2F;two-factor&#x2F;login]]></title><description><![CDATA[<p dir="auto">We have an application that is trying to complete a two-factor login via the API, but we are getting a 404 on /api/two-factor/login which is what the API docs indicate to use (<a href="https://fusionauth.io/docs/v1/tech/apis/login#complete-multi-factor-authentication" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/login#complete-multi-factor-authentication</a>).</p>
<p dir="auto">Has the endpoint changed?  We are using the Java FusionAuth Client Library (version 1.36.0) and Fusion Auth Self Hosted (version 1.36.6).</p>
<p dir="auto">Please let me know if additional information is needed.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2110/404-api-two-factor-login</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:09:20 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2110.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jun 2022 17:44:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 404 &#x2F;api&#x2F;two-factor&#x2F;login on Wed, 29 Jun 2022 20:29:11 GMT]]></title><description><![CDATA[<p dir="auto">We managed to figure it out.  It was a build error where IntelliJ was not updating the dependency.  Thanks for the help.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5284</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5284</guid><dc:creator><![CDATA[ethanmcgee]]></dc:creator><pubDate>Wed, 29 Jun 2022 20:29:11 GMT</pubDate></item><item><title><![CDATA[Reply to 404 &#x2F;api&#x2F;two-factor&#x2F;login on Mon, 27 Jun 2022 22:43:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/680">@ethanmcgee</a> I'm not sure what is going on. Can you please provide step by step repro instructions?</p>
<p dir="auto">Also, was this working on a previous version of FusionAuth?</p>
<p dir="auto">Finally, sometimes it can be helpful to use curl to call the APIs directly as that removes any possible issues with the client library.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5278</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5278</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 27 Jun 2022 22:43:51 GMT</pubDate></item></channel></rss>
