<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Jwks doesn&#x27;t have key to match kid or alg from JWT (client credentials token)]]></title><description><![CDATA[<p dir="auto">Good day FusionAuth Team!</p>
<p dir="auto">I followed the instructions to configure and test OAuth Client Credentials Grant with Entities [<a href="https://fusionauth.io/docs/v1/tech/oauth/#example-client-credentials-grant" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/oauth/#example-client-credentials-grant</a>], but the JWT access token that was produced has a kid that is not in our JWKS endpoint (/.well-known/jwks.json), therefore we can't pass authentication in our system.</p>
<p dir="auto">On the same tenant, when a user logs in with the Authorization Code Grant Flow with PKCE, the key is signed with the kid that is in the JWKS endpoint (/.well-known/jwks.json). So everything works fine.</p>
<p dir="auto">Am I missing something here?</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2150/jwks-doesn-t-have-key-to-match-kid-or-alg-from-jwt-client-credentials-token</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 15:21:44 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2150.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Aug 2022 18:58:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Jwks doesn&#x27;t have key to match kid or alg from JWT (client credentials token) on Fri, 19 Aug 2022 00:13:47 GMT]]></title><description><![CDATA[<p dir="auto">The tenant is using the "<strong>Default signing key (HS256)</strong>" for the access token.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5404</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5404</guid><dc:creator><![CDATA[vlad.koshkarov]]></dc:creator><pubDate>Fri, 19 Aug 2022 00:13:47 GMT</pubDate></item></channel></rss>
