<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[java.sql.SQLTransientConnectionException seen]]></title><description><![CDATA[<p dir="auto">We see this happening very now and then with both pgBouncer and Stolon when FusionAuth is connected to either. Any insights?</p>
<p dir="auto">This appears to be the problem: <code>HikariPool-1 - Connection is not available, request timed out after 4732ms.</code></p>
<pre><code>Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 4732ms.
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:150)
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:141)
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectOne(DefaultSqlSession.java:77)
	at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:357)
	at com.sun.proxy.$Proxy46.selectOne(Unknown Source)
	at org.apache.ibatis.session.SqlSessionManager.selectOne(SqlSessionManager.java:166)
	at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:83)
	at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:59)
	at com.sun.proxy.$Proxy47.retrieve(Unknown Source)
	at io.fusionauth.api.service.system.DefaultSystemConfigurationService.retrieve(DefaultSystemConfigurationService.java:57)
	at io.fusionauth.app.primeframework.CORSRequestWorkflow.&lt;init&gt;(CORSRequestWorkflow.java:32)
	at io.fusionauth.app.primeframework.CORSRequestWorkflow$$FastClassByGuice$$c8e3da99.newInstance(&lt;generated&gt;)
	at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
	at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42)
	at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65)
	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113)
	at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62)
	at com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1050)
	... 24 more
Caused by: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 4732ms.
]]></description><link>https://fusionauth.io/community/forum/topic/218/java-sql-sqltransientconnectionexception-seen</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:33:39 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/218.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Jul 2020 15:21:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to java.sql.SQLTransientConnectionException seen on Mon, 20 Jul 2020 01:22:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/169">@civaxox259</a><br />
you fix you problem  on `https://libroslara.com/libros/<br />
becouse i donde see any problem on tha page</p>
]]></description><link>https://fusionauth.io/community/forum/post/611</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/611</guid><dc:creator><![CDATA[civaxox259]]></dc:creator><pubDate>Mon, 20 Jul 2020 01:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to java.sql.SQLTransientConnectionException seen on Mon, 13 Jul 2020 14:49:58 GMT]]></title><description><![CDATA[<p dir="auto">Can you explain a bit more <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/169">@civaxox259</a> ?</p>
]]></description><link>https://fusionauth.io/community/forum/post/575</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/575</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 13 Jul 2020 14:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to java.sql.SQLTransientConnectionException seen on Mon, 13 Jul 2020 14:49:45 GMT]]></title><description><![CDATA[<p dir="auto">when  i  navigate to `https://libroslara.com/  i have the same problemes</p>
<p dir="auto">i'm  wonder if you fix the problem</p>
]]></description><link>https://fusionauth.io/community/forum/post/569</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/569</guid><dc:creator><![CDATA[civaxox259]]></dc:creator><pubDate>Mon, 13 Jul 2020 14:49:45 GMT</pubDate></item><item><title><![CDATA[Reply to java.sql.SQLTransientConnectionException seen on Thu, 09 Jul 2020 15:22:07 GMT]]></title><description><![CDATA[<p dir="auto">This may be related: <a href="https://github.com/brettwooldridge/HikariCP/issues/1042" rel="nofollow ugc">https://github.com/brettwooldridge/HikariCP/issues/1042</a></p>
<p dir="auto">Perhaps changing from transaction mode to session mode in pgBouncer may help?</p>
]]></description><link>https://fusionauth.io/community/forum/post/550</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/550</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 09 Jul 2020 15:22:07 GMT</pubDate></item></channel></rss>
