<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Configure Identity Providers per tenant]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have the following use case:</p>
<p dir="auto">I am developing a multi-tenant SaaS with Fusionauth as IAM. Each tenant (customer) of our application gets its own tenant in Fusionauth. Each tenant should be able to configure itself whether its users can log in via SAML / OICD with an external IdP - e.g. the company's own Azure AD or Google Workspace.</p>
<p dir="auto">I see from the documentation that the identity providers are intended for this and Fusionauth acts as a "service provider", correct?</p>
<p dir="auto">Unfortunately, it seems to me that identity providers can only be configured for the entire Fusionauth instance, but not individually for each tenant. Is this the case?</p>
<p dir="auto">If so, how can my use case be realised otherwise with Fusionauth?</p>
<p dir="auto">Thank you very much,<br />
Kind regards</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2200/configure-identity-providers-per-tenant</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:39:01 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2200.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Oct 2022 14:13:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Configure Identity Providers per tenant on Sat, 10 Dec 2022 16:42:30 GMT]]></title><description><![CDATA[<p dir="auto">@impackt Great, glad you have a path forward.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5751</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5751</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sat, 10 Dec 2022 16:42:30 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Identity Providers per tenant on Sun, 06 Nov 2022 21:41:23 GMT]]></title><description><![CDATA[<p dir="auto">Okay, got it, so currently you need a little self built workaround. Thank you very much!</p>
<p dir="auto">The tickets read exciting in principle, but are not currently relevant for me.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5636</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5636</guid><dc:creator><![CDATA[bubblez]]></dc:creator><pubDate>Sun, 06 Nov 2022 21:41:23 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Identity Providers per tenant on Mon, 10 Oct 2022 21:26:10 GMT]]></title><description><![CDATA[<p dir="auto">@impackt</p>
<p dir="auto">Hiya,</p>
<p dir="auto">Identity providers are configured globally, but are enabled on a per application basis. <a href="https://fusionauth.io/docs/v1/tech/identity-providers/#identity-providers-and-applications" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/identity-providers/#identity-providers-and-applications</a> has more info.</p>
<p dir="auto">What many of our users in your situation do is build a lightweight custom application that uses the FusionAuth APIs (<a href="https://fusionauth.io/docs/v1/tech/apis/identity-providers/samlv2" rel="nofollow ugc">SAMLv2</a> / <a href="https://fusionauth.io/docs/v1/tech/apis/identity-providers/openid-connect" rel="nofollow ugc">OIDC</a>) to allow your users to manage their own identity provider. That identity provider can then be associated only with the one application which represents the customer's application.</p>
<p dir="auto">We have a couple of open issues to improve this setup:</p>
<li><a href="https://github.com/fusionauth/fusionauth-issues/issues/91" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues/91</a></li>
<li><a href="https://github.com/FusionAuth/fusionauth-issues/issues/1524" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1524</a></li>
<p dir="auto">Please upvote them if they meet your needs, or add comments about your use case if you'd like.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5551</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5551</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 10 Oct 2022 21:26:10 GMT</pubDate></item></channel></rss>
