<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Set up SSL for Netty]]></title><description><![CDATA[<p dir="auto">With the switch from Tomcat to Netty in 1.37, is it possible to add an SSL certificate directly to Netty, as was possible with Tomcat? Perhaps via some configuration file?</p>
<p dir="auto">Related post:<br />
<a href="https://fusionauth.io/community/forum/topic/180/is-it-possible-to-set-up-ssl-for-fusionauth-directly">https://fusionauth.io/community/forum/topic/180/is-it-possible-to-set-up-ssl-for-fusionauth-directly</a></p>
]]></description><link>https://fusionauth.io/community/forum/topic/2216/set-up-ssl-for-netty</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 07:42:10 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2216.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Oct 2022 21:33:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Set up SSL for Netty on Fri, 21 Oct 2022 21:03:01 GMT]]></title><description><![CDATA[<p dir="auto">We will be moving off Netty to a new HTTP server in the coming weeks. This new server will have the ability to add TLS keys and we are expecting that to be available via the FusionAuth configuration file. In the meantime, the best solution is to use Nginx or Apache in front of FusionAuth to provide TLS.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5582</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5582</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 21 Oct 2022 21:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to Set up SSL for Netty on Fri, 21 Oct 2022 21:33:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/9">@voidmain</a> Thank you!</p>
]]></description><link>https://fusionauth.io/community/forum/post/5583</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5583</guid><dc:creator><![CDATA[pclark]]></dc:creator><pubDate>Fri, 21 Oct 2022 21:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Set up SSL for Netty on Fri, 21 Oct 2022 21:03:01 GMT]]></title><description><![CDATA[<p dir="auto">We will be moving off Netty to a new HTTP server in the coming weeks. This new server will have the ability to add TLS keys and we are expecting that to be available via the FusionAuth configuration file. In the meantime, the best solution is to use Nginx or Apache in front of FusionAuth to provide TLS.</p>
]]></description><link>https://fusionauth.io/community/forum/post/5582</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5582</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 21 Oct 2022 21:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to Set up SSL for Netty on Thu, 20 Oct 2022 21:45:47 GMT]]></title><description><![CDATA[<p dir="auto">Is adding an SSL cert to the keystore as described in <a href="https://fusionauth.io/docs/v1/tech/admin-guide/securing" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/admin-guide/securing</a> "Custom Certificate Authority" functionally equivalent to adding the cert to a standalone keystore, then using that keystore in Tomcat via the server.xml config file? Or is the  "Custom Certificate Authority" for a different use?</p>
]]></description><link>https://fusionauth.io/community/forum/post/5579</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5579</guid><dc:creator><![CDATA[pclark]]></dc:creator><pubDate>Thu, 20 Oct 2022 21:45:47 GMT</pubDate></item></channel></rss>
