<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CLI for managing config?]]></title><description><![CDATA[<p dir="auto">Do you have a command line tool for deploy/config of orgs/apps/etc, kindof like auth0's?  I know there are APIs, and a terraform provider; are there any alternatives?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2330/cli-for-managing-config</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 13:47:49 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2330.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Feb 2023 18:30:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CLI for managing config? on Wed, 18 Oct 2023 16:36:12 GMT]]></title><description><![CDATA[<p dir="auto">A CLI tool for managing configuration can be super handy for those who love working from the terminal. There are definitely some robust APIs and terraform providers you've pointed out.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6700</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6700</guid><dc:creator><![CDATA[fatimahdorsey632]]></dc:creator><pubDate>Wed, 18 Oct 2023 16:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to CLI for managing config? on Fri, 28 Jul 2023 15:35:57 GMT]]></title><description><![CDATA[<p dir="auto">Update: we're working on a CLI tool. It's early days and for now only manages themes, but we have work underway to manage email templates and lambdas as well.</p>
<p dir="auto">You can view and contribute here: <a href="https://github.com/fusionauth/fusionauth-node-cli" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-node-cli</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/6361</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6361</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 28 Jul 2023 15:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to CLI for managing config? on Thu, 27 Jul 2023 09:28:27 GMT]]></title><description><![CDATA[<p dir="auto">I totally get where you're coming from. Having a reliable command line tool for managing configurations, orgs, and apps is crucial for a seamless workflow.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6354</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6354</guid><dc:creator><![CDATA[sadiyaadamu721]]></dc:creator><pubDate>Thu, 27 Jul 2023 09:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to CLI for managing config? on Fri, 03 Mar 2023 08:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/5974">CLI for managing config?</a>:</p>
<p dir="auto">There are several options available for deploying and configuring orgs and apps, including using APIs or Terraform providers, as you mentioned. Other options may include using third-party tools or developing custom scripts for deployment and configuration. It would be best to research and evaluate the available options based on your specific needs and requirements<a href="https://www.mysutteronline.us/" rel="nofollow ugc">.</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/6013</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6013</guid><dc:creator><![CDATA[janettabloomquist]]></dc:creator><pubDate>Fri, 03 Mar 2023 08:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to CLI for managing config? on Mon, 27 Feb 2023 22:55:55 GMT]]></title><description><![CDATA[<p dir="auto">FWIW I ended up using mostly TF (and found some issues in the provider); plus writing some CLI in python using the rest library.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6012</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6012</guid><dc:creator><![CDATA[simon.roberts]]></dc:creator><pubDate>Mon, 27 Feb 2023 22:55:55 GMT</pubDate></item><item><title><![CDATA[Reply to CLI for managing config? on Mon, 27 Feb 2023 18:31:01 GMT]]></title><description><![CDATA[<p dir="auto">Here are options for config management: <a href="https://fusionauth.io/docs/v1/tech/admin-guide/configuration-management" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/admin-guide/configuration-management</a></p>
<p dir="auto">We don't have a CLI tool, but you could:</p>
<li>use the REST APIs and a tool like <a href="https://rest.sh" rel="nofollow ugc">https://rest.sh</a></li>
<li>use one of the client libraries: <a href="https://fusionauth.io/docs/v1/tech/client-libraries/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/client-libraries/</a> to build your own in python/ruby/etc</li>
]]></description><link>https://fusionauth.io/community/forum/post/5975</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5975</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 27 Feb 2023 18:31:01 GMT</pubDate></item></channel></rss>
