<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Updates and custom themes]]></title><description><![CDATA[<p dir="auto">How do people handle FusionAuth updates when they use custom themes? There seem to be a lot of base theme updates with every release. I know KeyCloak had a way to reference a parent theme so that it would fall back to templates and content not in the custom theme. But I don't believe the same kind of thing exists here.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2409/updates-and-custom-themes</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 04:54:52 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2409.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Jun 2023 12:47:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Updates and custom themes on Tue, 04 Jul 2023 02:35:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2485">@billyudi</a> We are working on a update to the upgrade guide which will discuss how to map the new theme files and changes.</p>
<p dir="auto">You can follow along with it here:</p>
<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-site/pull/2166" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-site/pull/2166</a></p>
<p dir="auto">I get your larger question though, which is, if I customize my theme, and then I upgrade from 1.45 to 1.46 and 1.46 introduces a new themed page, what does that new themed page look like?</p>
<p dir="auto">Have you tried testing this out?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6268</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6268</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 04 Jul 2023 02:35:01 GMT</pubDate></item></channel></rss>
