<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Insufficient memory error while running Fusion auth using docker compose]]></title><description><![CDATA[<p dir="auto">I am getting error on running the fusion auth using docker compose.</p>
<p dir="auto">fusionauth:<br />
image: fusionauth/fusionauth-app:latest<br />
container_name: fusionauth<br />
restart: always<br />
environment:<br />
- DATABASE_URL=jdbc:postgresql://postgres:5432/fusionauth<br />
- DATABASE_ROOT_USERNAME=&lt;username&gt;<br />
- DATABASE_ROOT_PASSWORD=&lt;password&gt;<br />
- DATABASE_USERNAME=&lt;username&gt;<br />
- DATABASE_PASSWORD=&lt;password&gt;<br />
- FUSIONAUTH_APP_MEMORY=512m<br />
- FUSIONAUTH_APP_RUNTIME_MODE=development<br />
- FUSIONAUTH_APP_URL=http://fusionauth:9011<br />
- SEARCH_SERVERS=http://search:9200<br />
- SEARCH_TYPE=elasticsearch<br />
- ES_JAVA_OPTS="-Xms1g -XX:+UseG1GC -XX:MaxGCPauseMillis=200"<br />
ports:<br />
- 9011:9011<br />
Starting fusionauth-app...<br />
--&gt; Logging to /usr/local/fusionauth/logs/fusionauth-app.log<br />
[0.012s][warning][os,thread] Failed to start thread - pthread_create failed (EPERM) for attributes: stacksize: 1024k, guardsize: 4k, detached.</p>
<h1></h1>
<h1>There is insufficient memory for the Java Runtime Environment to continue.</h1>
<h1>Cannot create worker GC thread. Out of system resources.</h1>
<h1>An error report file with more information is saved as:</h1>
<h1>/usr/local/fusionauth/fusionauth-app/</h1>
]]></description><link>https://fusionauth.io/community/forum/topic/2437/insufficient-memory-error-while-running-fusion-auth-using-docker-compose</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 05:09:18 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2437.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jul 2023 19:05:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Insufficient memory error while running Fusion auth using docker compose on Sun, 16 Jul 2023 21:35:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2534">@bhardwajmunish88</a> From the stackoverflow link:</p>
<p dir="auto">According to this github issue this is corrected by using docker 20.10.5.</p>
<p dir="auto">Can you try with a later version of Docker? I think this is due to the Java Docker image, and isn't an issue with FusionAuth.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6308</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6308</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Sun, 16 Jul 2023 21:35:06 GMT</pubDate></item><item><title><![CDATA[Reply to Insufficient memory error while running Fusion auth using docker compose on Wed, 12 Jul 2023 15:20:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Here are the details.</p>
<p dir="auto">Client:<br />
Version:      17.09.0-ce<br />
API version:  1.32<br />
Go version:   go1.8.3<br />
Git commit:   afdb6d4<br />
Built:        Tue Sep 26 22:42:18 2017<br />
OS/Arch:      linux/amd64</p>
<p dir="auto">Server:<br />
API version:  1.32 (minimum version 1.12)<br />
Built:        Tue Sep 26 22:40:56 2017<br />
OS/Arch:      linux/amd64<br />
Experimental: false</p>
]]></description><link>https://fusionauth.io/community/forum/post/6302</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6302</guid><dc:creator><![CDATA[bhardwajmunish88]]></dc:creator><pubDate>Wed, 12 Jul 2023 15:20:21 GMT</pubDate></item><item><title><![CDATA[Reply to Insufficient memory error while running Fusion auth using docker compose on Wed, 12 Jul 2023 13:49:39 GMT]]></title><description><![CDATA[<p dir="auto">Hmmm. What version of docker are you using?</p>
<p dir="auto"><a href="https://stackoverflow.com/questions/72546901/why-my-jib-container-failed-to-start-pthread-create-failed-eperm" rel="nofollow ugc">https://stackoverflow.com/questions/72546901/why-my-jib-container-failed-to-start-pthread-create-failed-eperm</a> indicates it is related to that.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6301</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6301</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 12 Jul 2023 13:49:39 GMT</pubDate></item></channel></rss>
