<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Salesforce error: Id_Token_Error: Missing or invalid iss]]></title><description><![CDATA[<p dir="auto">Hi, we are tying to set up a salesforce SB to work with a dev site using fusion. when using test url we are getting the following error:</p>
<p dir="auto">We can’t log you in because of the following error.<br />
Id_Token_Error: Missing or invalid iss</p>
<p dir="auto">we are passing the our dev site as the token as described here: <a href="https://fusionauth.io/docs/v1/tech/oauth/integrations/salesforce" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/oauth/integrations/salesforce</a></p>
<p dir="auto">Any idea on what can be the reason for this error?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2448/salesforce-error-id_token_error-missing-or-invalid-iss</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 16:03:43 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2448.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Jul 2023 20:07:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Salesforce error: Id_Token_Error: Missing or invalid iss on Wed, 23 Aug 2023 14:30:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2550">@yuval</a> Thanks for following up and sharing with the community.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6463</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6463</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 23 Aug 2023 14:30:17 GMT</pubDate></item><item><title><![CDATA[Reply to Salesforce error: Id_Token_Error: Missing or invalid iss on Wed, 23 Aug 2023 09:04:43 GMT]]></title><description><![CDATA[<p dir="auto">The problem was a wrong token issuer defined in SF auth. provider configuration.  Our The SF Auth. Provider token issuer field need to have the same VALUE as defined in FusionAuth (for example <a href="http://acme.com" rel="nofollow ugc">acme.com</a>) and not the url of the instance as described in the help document. (<a href="https://your.fusionauth.application.url" rel="nofollow ugc">https://your.fusionauth.application.url</a>)</p>
]]></description><link>https://fusionauth.io/community/forum/post/6456</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6456</guid><dc:creator><![CDATA[yuval]]></dc:creator><pubDate>Wed, 23 Aug 2023 09:04:43 GMT</pubDate></item><item><title><![CDATA[Reply to Salesforce error: Id_Token_Error: Missing or invalid iss on Tue, 25 Jul 2023 14:13:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2550">@yuval</a>,<br />
I'm not very familiar with Salesforce but when taking a look at the guide there is a step that says "<em>Scroll down to the Salesforce Configuration section and open the address from Test-Only Initialization URL in an incognito window.</em>". What do you see when you try that?</p>
<p dir="auto">If you are not getting that information, can you please describe in a little more detail what steps you have taken and when you receive the above message about the invalid iss?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6338</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6338</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Tue, 25 Jul 2023 14:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Salesforce error: Id_Token_Error: Missing or invalid iss on Thu, 20 Jul 2023 15:17:54 GMT]]></title><description><![CDATA[<p dir="auto">Anyone from FusionAuth can give us a hint? we are passing the site url as token issuer, is this right?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6335</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6335</guid><dc:creator><![CDATA[yuval]]></dc:creator><pubDate>Thu, 20 Jul 2023 15:17:54 GMT</pubDate></item></channel></rss>
