<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Advanced Multi-Factor Authentication feature with Application configuration required]]></title><description><![CDATA[<p dir="auto">We purchased a starter license and currently use Fusion Auth 1.44.0</p>
<p dir="auto">Starter license comes with Advanced MFA<br />
Setting up the MFA policy in the tenant works fine, every app will use the MFA tenant policy.</p>
<p dir="auto">According to <a href="https://fusionauth.io/docs/v1/tech/guides/multi-factor-authentication#application-set-up" rel="nofollow ugc">the docs</a> you are able to overwrite tenant MFA config per application.<br />
When trying to make any changes in the tab MFA or advanced in the application UI I get following error<br />
<em>Advanced Multi-Factor Authentication feature with Application configuration required</em></p>
<p dir="auto">After having a close look at the docs it says you need an enterprise licence while the error nor the pricing table says that this feature is only applicable with an enterprise license.</p>
<p dir="auto">So what is correct, is this feature only applicable to an enterprise license and is the error message a bit misleading that you need to configure something or can I configure something within the scope of the starter license?</p>
<p dir="auto">If this feature is only available with an enterprise license why is this not listed in the pricing table when comparing all the licenses? IMO advanced MFA should also include overriding tenant config per application</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2482/advanced-multi-factor-authentication-feature-with-application-configuration-required</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 05:44:29 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2482.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Aug 2023 10:48:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Advanced Multi-Factor Authentication feature with Application configuration required on Mon, 28 Aug 2023 23:28:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi Martin, we updated the feature matrix here: <a href="https://fusionauth.io/pricing?step=plan&amp;hosting=self-hosting" rel="nofollow ugc">https://fusionauth.io/pricing?step=plan&amp;hosting=self-hosting</a> to make it clear that application specific MFA configuration is an enterprise only feature.</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://fusionauth.io/community/forum/post/6487</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6487</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 28 Aug 2023 23:28:33 GMT</pubDate></item><item><title><![CDATA[Reply to Advanced Multi-Factor Authentication feature with Application configuration required on Mon, 28 Aug 2023 22:02:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2608">@martijn-van-waardhuizen</a> ,</p>
<p dir="auto">Thanks for using FusionAuth.</p>
<p dir="auto">Per-application MFA configuration is reserved for enterprise plans <a href="https://fusionauth.io/docs/v1/tech/guides/multi-factor-authentication#application-set-up" rel="nofollow ugc">as documented</a>.  Advanced MFA includes SMS and email MFA methods.</p>
<p dir="auto">I've requested an update to the pricing table to make this clearer. Sorry about the hassle.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6486</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6486</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 28 Aug 2023 22:02:58 GMT</pubDate></item></channel></rss>
