<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Forwarding logs to a logging system]]></title><description><![CDATA[<p dir="auto">Regarding the logs that are available over the web ui (event logs, audit logs, log records), can they be forwarded to a logging system?</p>
<p dir="auto">Looking to put them into something like graylog.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2485/forwarding-logs-to-a-logging-system</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 15:58:24 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2485.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Aug 2023 22:53:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Forwarding logs to a logging system on Tue, 29 Aug 2023 22:55:20 GMT]]></title><description><![CDATA[<p dir="auto">We have <a href="https://fusionauth.io/docs/v1/tech/admin-guide/monitor#overview" rel="nofollow ugc">documentation that describes how you can monitor FusionAuth</a>.</p>
<p dir="auto">Each of the logs that you mention has an API exposed that can be used to consume FusionAuth data into an external system.</p>
<p dir="auto">At this time, you'll need to write scripts, using the client libraries, to scrape and ingest these logs.</p>
<p dir="auto">If you are looking to get webhooks into a system, we have an <a href="https://github.com/FusionAuth/fusionauth-example-lambda-webhook" rel="nofollow ugc">example AWS lambda which pushes webhook events to S3</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6494</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6494</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 29 Aug 2023 22:55:20 GMT</pubDate></item></channel></rss>
