<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing IP addresses for login records?]]></title><description><![CDATA[<p dir="auto">I am noticing a few of the logs are missing IP addresses for login records.</p>
<p dir="auto">Do you guys have any insight on why this is happening and/or if it can be resolved?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/250/missing-ip-addresses-for-login-records</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 14:08:48 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/250.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Jul 2020 22:33:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing IP addresses for login records? on Thu, 23 Jul 2020 22:34:25 GMT]]></title><description><![CDATA[<p dir="auto">The short answer is that these events are from when the user was created or first registered for an application.</p>
<p dir="auto">When a user is first created, or registered for an application we create a login event because we generate a JWT and optionally a Refresh Token for the user.</p>
<p dir="auto">In these cases, we do not have an IP address to record in the login event.</p>
<p dir="auto">We have discussed adding the IP address from the API request, but this is likely a back end system or internal service and the IP address would not represent the location of the end user, and so would likely not be of great use.</p>
]]></description><link>https://fusionauth.io/community/forum/post/688</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/688</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 23 Jul 2020 22:34:25 GMT</pubDate></item></channel></rss>
