<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error validating SAML logout request]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">We have just started with Fusion Auth using a purely SAML integration and have hit an issue with a service proivder intiated logout request</p>
<p dir="auto">We think we have the configuration correct but after the user is redirected to the fusion auth logout page a call is made from the UI to the following end point, which results in the error shown below</p>
<p dir="auto"><a href="https://fa-dev.elateral-dev.io/samlv2/logout/complete" rel="nofollow ugc">https://fa-dev.elateral-dev.io/samlv2/logout/complete</a></p>
<p dir="auto">The SAMLRequest and signiture validate ok for us in a saml validation tool, guessing its some sort of configuration we have wrong.</p>
<pre><code>fusionauth 2023-09-26 09:44:25.959 AM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
fusionauth java.lang.NullPointerException: null
fusionauth     at java.base/java.util.ImmutableCollections$ListN.indexOf(ImmutableCollections.java:716)
fusionauth     at java.base/java.util.ImmutableCollections$AbstractImmutableList.contains(ImmutableCollections.java:329)
fusionauth     at io.fusionauth.api.service.samlv2.DefaultSAMLv2ProviderService.validateRequest(DefaultSAMLv2ProviderService.java:522)
fusionauth     at io.fusionauth.api.service.samlv2.DefaultSAMLv2ProviderService.validateLogoutRequest(DefaultSAMLv2ProviderService.java:466)
fusionauth     at io.fusionauth.app.action.samlv2.logout.CompleteAction.lambda$post$0(CompleteAction.java:53)
fusionauth     at io.fusionauth.app.action.samlv2.BaseSAMLAction.handleSAMLException(BaseSAMLAction.java:111)
fusionauth     at io.fusionauth.app.action.samlv2.logout.CompleteAction.post(CompleteAction.java:41)
fusionauth     at jdk.internal.reflect.GeneratedMethodAccessor475.invoke(Unknown Source)
fusionauth     at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
fusionauth     at java.base/java.lang.reflect.Method.invoke(Method.java:568)
fusionauth     at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443)
fusionauth     at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77)
fusionauth     at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60)
fusionauth     at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50)
fusionauth     at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50)
fusionauth     at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45)
fusionauth     at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:60)
fusionauth     at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49)
fusionauth     at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74)
fusionauth     at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58)
fusionauth     at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92)
fusionauth     at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50)
fusionauth     at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:113)
fusionauth     at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65)
fusionauth     at org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:65)
fusionauth     at org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:108)
fusionauth     at org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:72)
fusionauth     at io.fusionauth.http.server.HTTPWorker.run(HTTPWorker.java:50)
fusionauth     at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
fusionauth     at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
fusionauth     at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
fusionauth     at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
fusionauth     at java.base/java.lang.Thread.run(Thread.java:833)
<p dir="auto">Any help much appreciated!</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2513/error-validating-saml-logout-request</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 01:53:10 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2513.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Sep 2023 10:00:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error validating SAML logout request on Tue, 03 Oct 2023 11:48:51 GMT]]></title><description><![CDATA[<p dir="auto">Found the cause and the solution with the help of Joshua on support</p>
<p dir="auto">The SAML logout request was generated by a library we are using, saml2-js. It seems this library had an outstanding pull request to fix the SAML logout request to add in the nameid_format attribute to the nameid element in the logout request. Setting this attribute solved the problem, as per Joshua's suggestion:</p>
<p dir="auto">Ideally, when completing a logout request, FusionAuth is provided a Name Id format of:<br />
urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress<br />
or<br />
urn:oasis:names:tc:SAML:2.0:nameid-format:persistent</p>
]]></description><link>https://fusionauth.io/community/forum/post/6636</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6636</guid><dc:creator><![CDATA[anthony.hollingsworth]]></dc:creator><pubDate>Tue, 03 Oct 2023 11:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to Error validating SAML logout request on Mon, 02 Oct 2023 22:52:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> continuing in a support thread.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6629</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6629</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Mon, 02 Oct 2023 22:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to Error validating SAML logout request on Mon, 02 Oct 2023 21:28:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2649">@anthony-hollingsworth</a> !</p>
<p dir="auto">Welcome to the FusionAuth community!</p>
<p dir="auto">What version of FusionAuth are you running?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6620</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6620</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 02 Oct 2023 21:28:38 GMT</pubDate></item></channel></rss>
