<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HTTPS in 1.47.1 doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">When I enable HTTPS in 1.47.1, I'm able to connect to the admin interface and everything looks fine. However, when I try to login as an admin, I get the error shown below:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1696016971408-cleanshot-2023-09-29-at-14.50.47-2x.png" alt="CleanShot 2023-09-29 at 14.50.47@2x.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is running on a Ubuntu 22 server, installed from the Debian package. I configured the HTTPS in <code>fusionauth.properties</code> as follows:</p>
<pre><code>fusionauth-app.https.enabled=true
fusionauth-app.https.port=9013
fusionauth-app.https.certificate-file=/path/to/my/certificate.crt
fusionauth-app.https.private-key-file=/path/to/my/key.key
<p dir="auto">When I login via HTTP, the admin interface comes right up.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2521/https-in-1-47-1-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 06:10:03 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2521.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Sep 2023 19:53:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HTTPS in 1.47.1 doesn&#x27;t work on Thu, 05 Oct 2023 03:47:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2680">@brad</a> Hmm. Thanks for the feedback. Seems like it should have worked.</p>
<p dir="auto">If you feel like it, please log an issue on our GH issues list: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/</a> with as much detail as you would like. Feel free to reference this issue.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6652</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6652</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 05 Oct 2023 03:47:16 GMT</pubDate></item><item><title><![CDATA[Reply to HTTPS in 1.47.1 doesn&#x27;t work on Wed, 04 Oct 2023 21:18:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> No, nothing that seemed relevant. I ended up using Cloudflare as a proxy. That works fine, but it would be simpler to just enable HTTPS in FusionAuth.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6651</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6651</guid><dc:creator><![CDATA[brad]]></dc:creator><pubDate>Wed, 04 Oct 2023 21:18:15 GMT</pubDate></item><item><title><![CDATA[Reply to HTTPS in 1.47.1 doesn&#x27;t work on Mon, 02 Oct 2023 22:09:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2680">@brad</a></p>
<p dir="auto">Hmmm.</p>
<p dir="auto">Did you see any errors in the system logs?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6625</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6625</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 02 Oct 2023 22:09:35 GMT</pubDate></item></channel></rss>
