<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I call a Google API or retrieve the Google credentials?]]></title><description><![CDATA[<p dir="auto">I created a Google Identity Provider using the OpenID connection. I did this so I could implement everything via the fusionauth API so I could have my own login screen. It works great. I am able to create a user by allowing them to sign up with Google.</p>
<p dir="auto">I have the sensitive calendar Google API scope which the user authorizes.</p>
<p dir="auto">In my current application with FusionAuth username and password I ask the user to connect their calendar manually and Google sends back a key like this:<br />
<img src="/community/forum/assets/uploads/files/1701298263331-2bf0dab9-eea2-4f2e-ac2a-4f5eca5c6629-image.png" alt="2bf0dab9-eea2-4f2e-ac2a-4f5eca5c6629-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now I want to make it easier for the user and provider sign in with Google authenticate for their calendar as you do with Calendly.</p>
<p dir="auto">My problem is that once I authenticate with Google, how do I get the authentication token from Google? Normally this key looks like the picture I posted above. However when I query the identityToken I get this:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1701298883511-f5d88013-7074-464b-b079-567c11f83f04-image-resized.png" alt="f5d88013-7074-464b-b079-567c11f83f04-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">2 problems are that</p>
<li>The token is empty, and</li>
<li>I am not even sure that if it were there it would be a JSON token as I use for the Google Calendar.</li>
<p dir="auto">I need to take this credential and store it on my database as I do now for calendar authentication.</p>
<p dir="auto">I can not seem to find a way to get that credential from FusionAuth to call the Google Calendar API</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2569/how-do-i-call-a-google-api-or-retrieve-the-google-credentials</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 03:21:20 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2569.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Nov 2023 23:04:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Wed, 21 Aug 2024 05:35:29 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for sharing.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7477</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7477</guid><dc:creator><![CDATA[helen]]></dc:creator><pubDate>Wed, 21 Aug 2024 05:35:29 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Tue, 13 Aug 2024 16:26:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for sharing the information..</p>
]]></description><link>https://fusionauth.io/community/forum/post/7462</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7462</guid><dc:creator><![CDATA[william 0]]></dc:creator><pubDate>Tue, 13 Aug 2024 16:26:03 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Mon, 15 Jul 2024 15:22:13 GMT]]></title><description><![CDATA[<p dir="auto">I do this all the time and keep meaning to create a post on codingcat.dev for it instead of hitting Jeff's site for it all the time. In the meantime I would suggest checking this out it always works for me <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":smile:" alt="😄" /></p>
<p dir="auto"><a href="https://fireship.io/lessons/google-apis-node-tutorial/" rel="nofollow ugc">https://fireship.io/lessons/google-apis-node-tutorial/</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7373</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7373</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 15 Jul 2024 15:22:13 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Mon, 15 Jul 2024 08:58:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3095">@ehabmohsen66</a> The information you provided is very helpful. Thanks for it.</p>
<p dir="auto">But can you elaborate on the google developer console?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7372</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7372</guid><dc:creator><![CDATA[dom9]]></dc:creator><pubDate>Mon, 15 Jul 2024 08:58:36 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Mon, 01 Jul 2024 16:56:41 GMT]]></title><description><![CDATA[<pre><code></code></pre>
<p dir="auto">coHi there,</p>
<p dir="auto">To call a Google API or retrieve the Google credentials in FusionAuth, you can follow these steps:</p>
<p dir="auto"><strong>Create a Google Cloud Project</strong>:</p>
<li>Go to the <a href="https://console.cloud.google.com/" rel="nofollow ugc">Google Cloud Console</a>.</li>
<li>Create a new project or select an existing one.</li>
<li>Navigate to the API &amp; Services section and enable the API you need.</li>
<p dir="auto"><strong>Set Up OAuth 2.0 Credentials</strong>:</p>
<li>In the API &amp; Services section, go to Credentials.</li>
<li>Click on "Create Credentials" and select "OAuth 2.0 Client IDs".</li>
<li>Set up the consent screen and configure the OAuth 2.0 Client ID.</li>
<li>Note down the Client ID and Client Secret.</li>
<p dir="auto"><strong>Configure FusionAuth</strong>:</p>
<li>In FusionAuth, go to "Identity Providers".</li>
<li>Add a new "OpenID Connect" provider.</li>
<li>Enter the details from your Google Cloud Project:
<li>Authorization endpoint: <code>https://accounts.google.com/o/oauth2/v2/auth</code></li>
<li>Token endpoint: <code>https://oauth2.googleapis.com/token</code></li>
<li>User info endpoint: <code>https://openidconnect.googleapis.com/v1/userinfo</code></li>
<li>Client ID and Client Secret from your Google Cloud Project.</li>
<p dir="auto"><strong>Test the Integration</strong>:</p>
<li>Ensure your FusionAuth instance is properly set up to handle the authentication flow.</li>
<li>Test logging in with Google to verify everything is working.</li>
<p dir="auto">For more detailed steps, you might find this <a href="https://fusionauth.io/docs/v1/tech/identity-providers/openid-connect" rel="nofollow ugc">FusionAuth documentation</a> useful.</p>
<p dir="auto">If you need assistance with digital marketing strategies, feel free to visit my digital marketing agency, <a href="https://digitology.co" rel="nofollow ugc">Digitology</a>, where we specialize in helping businesses grow online.</p>
<p dir="auto">Best of luck with your integration!</p>
]]></description><link>https://fusionauth.io/community/forum/post/7364</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7364</guid><dc:creator><![CDATA[ehabmohsen66]]></dc:creator><pubDate>Mon, 01 Jul 2024 16:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Mon, 11 Dec 2023 08:19:50 GMT]]></title><description><![CDATA[<p dir="auto">To call a Google API or retrieve Google credentials, you typically need to follow these steps:</p>
<p dir="auto">Create a Project in the Google Cloud Console:</p>
<p dir="auto">Go to the Google Cloud Console<a href="www-liteblue.us" rel="nofollow ugc">.</a><br />
Create a new project or select an existing one.<br />
Enable APIs:</p>
<p dir="auto">In the Cloud Console, navigate to the "APIs &amp; Services" &gt; "Dashboard."<br />
Click on "+ ENABLE APIS AND SERVICES."<br />
Search for the API you want to use (e.g., Google Drive API) and enable it.<br />
Create Credentials<a href="https://www-liteblue.us/liteblue-epayroll/" rel="nofollow ugc">:</a></p>
<p dir="auto">After enabling the API, go to "APIs &amp; Services" &gt; "Credentials."<br />
Click on "Create Credentials."<br />
Choose the type of credentials you need (API key, OAuth client ID, etc.).<br />
Configure OAuth Consent Screen<a href="https://www-liteblue.us/liteblue-postalease/" rel="nofollow ugc">:</a></p>
<p dir="auto">If you're using OAuth, set up the OAuth consent screen with the required information.<br />
Download or Copy Credentials:</p>
<p dir="auto">Once you've created credentials, download or copy them. For OAuth client IDs, you might download a JSON file that contains your client ID and client secret.<br />
Use Credentials in Your Code:</p>
<p dir="auto">Integrate the credentials into your code. For example, if you're using OAuth, you'll use the client ID and secret to authenticate your application.</p>
<p dir="auto">Make sure to replace 'credentials.json' with the path to your downloaded JSON file containing the client ID and secret.</p>
<p dir="auto">Remember to handle your credentials securely and never expose them in publicly accessible code or repositories.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6852</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6852</guid><dc:creator><![CDATA[owork138]]></dc:creator><pubDate>Mon, 11 Dec 2023 08:19:50 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Fri, 08 Dec 2023 15:03:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> Thank you all for your help with this issue! Thanks for the fast turnaround and the hard work here! Thanks again everyone!</p>
]]></description><link>https://fusionauth.io/community/forum/post/6847</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6847</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Fri, 08 Dec 2023 15:03:07 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Fri, 08 Dec 2023 01:54:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I see now from <a href="https://github.com/FusionAuth/fusionauth-issues/issues/2574#issuecomment-1846416213" rel="nofollow ugc">here</a>: that it is the refresh token, I see now that I should store the refresh token the first time and initially refresh that token to get an access token. Thank you <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a>!</p>
<p dir="auto">IMHO this one tiny detail is not clear enough, even though it in there. For example, in the <a href="https://fusionauth.io/docs/apis/identity-providers/links#retrieve-a-link" rel="nofollow ugc">Link API</a> it could mention again that the token is a refresh token. Instead it says this:</p>
<p dir="auto">This is treated as an opaque token as the type varies by identity provider, this value may not be returned by all identity providers. When provided, this token is typically a long lived access or refresh token, but consult individual identity provider documentation for specifics.</p>
<p dir="auto">That's not true though is it? It's a refresh token when one is available.</p>
<p dir="auto">While the details may be in the docs, IMHO it isn't extremely clear because OAuth is confusing for people in the first place, and FusionAuth is asking us to perform <em>some</em> but not <em>all</em> parts of the OAuth flow. The answer is spread throughout the docs. In the end if we want to create a custom login page with Google page we need to first:</p>
<li>Create an OpenID for Identity Provider for Google.</li>
<li>Create the Sign in Google URL on our own to call the sign in page.</li>
<li>When the flow comes back to our page we need to exchange the code with the FusionAuth API.</li>
<li>When that returns to our redirected url, we need to get the link API to get the refresh token in the <code>token</code>.</li>
<li>Exchange that refresh token for an access token, and I guess refresh the token on our own?</li>
<p dir="auto">However, in a flow without FusionAuth we'd get the access token and refresh token together, store both, and use the access token until it is expired, then use the refresh token.</p>
<p dir="auto">While it is possible to figure this out, it's just not as clear as the rest of the docs. Everything up to this point was well written and clear. This was hard to figure out from my POV.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6846</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6846</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Fri, 08 Dec 2023 01:54:10 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Fri, 08 Dec 2023 01:35:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Thanks for your response!<br />
I think our paths are getting crossed and I am still confused.</p>
<p dir="auto">Can you answer these questions:</p>
<li><code>token</code> that comes back from the <code>retrieveUserLinksByUserId</code> in the TypeScript SDK or <a href="https://fusionauth.io/docs/apis/identity-providers/links#retrieve-a-link" rel="nofollow ugc">Retrieve A Link(s)</a> in the Link API. Is it supposed to be the access token?</li>
<li>If that is the access token, how does the token get refreshed? Does that happen via FusionAuth?</li>
<li>I read the OpenID documentation from Google and their API returns <code>access_token</code>, <code>refresh_token</code>, and <code>id_token</code> keys in JSON, but nothing like <code>token</code>, so somewhere this is getting translated, but how does the <code>id_token</code> get translated or where is the functionality of the refresh token?</li>
]]></description><link>https://fusionauth.io/community/forum/post/6845</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6845</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Fri, 08 Dec 2023 01:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Fri, 08 Dec 2023 01:23:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> Thank you for your patience.  With my testing and the last bit of info you posted, I think you have uncovered a bug.  I was able to reproduce this in the UI now. Thank you so much for your effort here.  I have submitted this as bug in the FusionAuth Issues project <a href="https://github.com/FusionAuth/fusionauth-issues/issues/2574" rel="nofollow ugc">here</a> to follow if you are interested.</p>
<p dir="auto">Until that gets resolved, I think you will need to keep looking for the refresh token update it in an external source if it appears and link it on the user ID until the behavior is changed.</p>
<p dir="auto">While ideally we would like to keep this info all in FusionAuth, you may be able to set up a webhook that listens for a login and then if there is a value for the refresh token keep that in the user.data, but I have not tested that out.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6844</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6844</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 08 Dec 2023 01:23:53 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 07 Dec 2023 19:05:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I made some headway in finding out when the token is blank!</p>
<p dir="auto">It seems that the first time that I make a sign in with Google, the token is returned every time.</p>
<p dir="auto">Any subsequent calls to get identity provider links may or may not return the token. The only way to guarentee it comes back is to completely "forget" the oauth2 link in <a href="http://accounts.google.com" rel="nofollow ugc">accounts.google.com</a>, specifically here:  <a href="https://myaccount.google.com/connections" rel="nofollow ugc">https://myaccount.google.com/connections</a>.</p>
<p dir="auto">My solution is to save the token the first time it comes through in the database. There's one problem with this solution is that I don't have a refresh token for the user, so if this token expires I won't be able to refresh it, but I am only assuming that Fusion will refresh the token and return a new one for me. I have no idea if this is true or not.</p>
<p dir="auto">Since I can't see the source code of FusionAuth and the docs aren't clear about what kind of token this is, I can't say if this is going to work for sure.</p>
<p dir="auto">If you can give me more clarity into how this works</p>
]]></description><link>https://fusionauth.io/community/forum/post/6843</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6843</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 07 Dec 2023 19:05:34 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Wed, 06 Dec 2023 03:40:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> , just wanted to let you know I haven't forgotten about this.  I was able to get the scopes to work today through the regular login.  I should have some time over the next few days to test the api login.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6835</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6835</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 06 Dec 2023 03:40:10 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Sun, 03 Dec 2023 20:52:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Yes I have it set up. This is the reply I get from fusionauth</p>
<pre><code class="language-javascript">{
  "identityProviderLinks": [
      "displayName": "jsch...@gmail.com",
      "identityProviderId": "c43c909e-ada2-4731-b840-9e30e928c2a2",
      "identityProviderName": "Google OpenID",
      "identityProviderType": "OpenIDConnect",
      "identityProviderUserId": "110...3166",
      "insertInstant": 1701322547795,
      "lastLoginInstant": 1701636612288,
      "tenantId": "17470e59-34e8-4833-9c80-080d3abe09b3",
      "token": "",
      "userId": "ea855097-9b97-48fc-99ee-b9975a7e7a8b"
<p dir="auto">As you can see in this response from the server, the token is blank.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6832</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6832</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Sun, 03 Dec 2023 20:52:36 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 23:34:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I do have it set up as an idp.<br />
I am using openId because I could not get Google working from the API. I am not using the hosted login. I have built my own.<br />
I use the identity provider API route to complete the sign in.<br />
I just need the token. And I need to know that fusion is refreshing the tokens on my behalf.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6830</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6830</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 30 Nov 2023 23:34:38 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 22:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> do you have Google set up as and IdP in FusionAuth?  <a href="https://fusionauth.io/docs/apis/identity-providers/google" rel="nofollow ugc">https://fusionauth.io/docs/apis/identity-providers/google</a>. Would this flow work for you if the right scopes are provided?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6826</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6826</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Thu, 30 Nov 2023 22:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 18:59:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Here's how I am doing it with the Sign in with Google flow:</p>
<p dir="auto">Sign in with Google button on the home page has a generated url . That function looks like this for me:</p>
<pre><code>function generateGoogleOAuth2LoginUrl() {
  const { google } = require("googleapis");
  const redirectUrl = `${process.env.FRONT_ROOT}/sign-up/login-redirect`;
  const oauth2Client = new google.auth.OAuth2(
    process.env.GOOGLE_OAUTH_CLIENT_ID,
    process.env.GOOGLE_OAUTH_SECRET,
    redirectUrl
  let scopes = [
    "https://www.googleapis.com/auth/calendar",
    "https://www.googleapis.com/auth/userinfo.email",
    "https://www.googleapis.com/auth/userinfo.profile",
    "openid",
  return oauth2Client.generateAuthUrl({
    access_type: "offline",
    scope: scopes,
<p dir="auto">From there when the user logs in we are placed at <code>/sign-up/login-redirect</code></p>
<p dir="auto">I use the typescript fusionauth client to log in with google</p>
<pre><code>async function loginWithGoogle(code) {
  return client.identityProviderLogin({
    data: {
      code,
      redirect_uri: `${process.env.FRONT_ROOT}/sign-up/login-redirect`,
    applicationId: process.env.FUSION_AUTH_APP_ID,
    identityProviderId: process.env.GOOGLE_IDENTITY_PROVIDER_ID,
<p dir="auto">This works and from there I create my own internal user linked to FusionAuth</p>
<p dir="auto">From there I call to get the token from the link api</p>
<pre><code>async function getLinkedAccounts(userId) {
  const { response } = await client.retrieveUserLinksByUserId(
    userId
  return response;
<p dir="auto">This works and gives me the user I am looking for however the <code>token</code> field is blank. Everything else is populated. I would call Google myself but only one of us can have the token.</p>
<p dir="auto">One assumption I am making is that FusionAuth is handling the token refresh on my behalf.</p>
<p dir="auto">The other way is with Username and Password authentication and I do all the Google calling myself, and I keep the credentials stored on my database.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6825</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6825</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 30 Nov 2023 18:59:19 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 18:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> Ok, can you tell me a little more about how you '...ask the user to connect their calendar manually'?</p>
<p dir="auto">It sounds like you are getting the token directly from Google and then are looking to store that in connection with the FusionAuth user?  Do I have that right?</p>
]]></description><link>https://fusionauth.io/community/forum/post/6824</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6824</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Thu, 30 Nov 2023 18:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 17:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> BTW I did add the appropriate scopes there:</p>
<p dir="auto"><code>https://www.googleapis.com/auth/calendar https://www.googleapis.com/auth/userinfo.email https://www.googleapis.com/auth/userinfo.profile openid</code></p>
]]></description><link>https://fusionauth.io/community/forum/post/6823</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6823</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 30 Nov 2023 17:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 17:15:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Thanks for the reply! I already spent 6 months getting that approval so we're good to go on scope, I just need to figure out the flow of getting the token.</p>
<p dir="auto">In my current flow without FusionAuth as Sign In With Google, I store the credential on our DB and do the token refreshing ourselves. It works great.</p>
<p dir="auto">Without the refresh token, I imagine we are going to request the token each time and FusionAuth does the refreshing of the token on our behalf?</p>
<p dir="auto">My remaining question: how do I get the token, and how do I ensure it will not be a blank string as above.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6822</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6822</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 30 Nov 2023 17:15:36 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 17:12:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2753">@jacob-0</a> have you taken a look at Google's calender scopes?  <a href="https://developers.google.com/identity/protocols/oauth2/scopes#calendar" rel="nofollow ugc">https://developers.google.com/identity/protocols/oauth2/scopes#calendar</a></p>
<p dir="auto">You will need to add the appropriate scope in the scopes section of the Identity Provider configuration.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6821</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6821</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Thu, 30 Nov 2023 17:12:11 GMT</pubDate></item><item><title><![CDATA[Reply to How do I call a Google API or retrieve the Google credentials? on Thu, 30 Nov 2023 00:37:34 GMT]]></title><description><![CDATA[<p dir="auto">BTW I understand that <a href="https://openid.net/specs/openid-connect-core-1_0.html#IDToken" rel="nofollow ugc">the token</a> is a part of the OpenID specification. So any sort of token would be great!</p>
]]></description><link>https://fusionauth.io/community/forum/post/6818</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6818</guid><dc:creator><![CDATA[jacob 0]]></dc:creator><pubDate>Thu, 30 Nov 2023 00:37:34 GMT</pubDate></item></channel></rss>
