<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does FusionAuth support WCAG?]]></title><description><![CDATA[<p dir="auto">How compliant is the login user interface with WCAG (Web Content Accessibility Guidelines).</p>
<p dir="auto">For instance, are the pages optimized for screen readers or other accessibility tooling?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2574/does-fusionauth-support-wcag</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 19:09:04 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2574.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Dec 2023 23:07:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does FusionAuth support WCAG? on Fri, 08 Dec 2023 23:07:58 GMT]]></title><description><![CDATA[<p dir="auto">FusionAuth does allow for extensive customization of themes, which may be used to ensure WCAG compliance.</p>
<p dir="auto">To create and manage themes, you can navigate to Customizations -&gt; Themes in the FusionAuth UI or API. More here: <a href="https://fusionauth.io/docs/customize/look-and-feel/" rel="nofollow ugc">https://fusionauth.io/docs/customize/look-and-feel/</a></p>
<p dir="auto">Themes are written in FreeMarker, which provides a rich template language to customize pages and helpers to suit your needs. This could include adding accessibility features to meet WCAG standards.<br />
If you need to manage complex configurations such as themes programmatically, you can use the FusionAuth CLI.</p>
<p dir="auto">If you're looking to ensure that your custom theme meets WCAG requirements, you might need to consult WCAG guidelines and ensure that your theme modifications align with those standards. This could involve adding appropriate ARIA labels, ensuring sufficient color contrast, providing keyboard navigation, and more.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6849</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6849</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 08 Dec 2023 23:07:58 GMT</pubDate></item></channel></rss>
