<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fusion 5 minute guide]]></title><description><![CDATA[<p dir="auto">I am brand new with Fusion Auth</p>
<p dir="auto">I am working on the 5 Minute Guide at <a href="https://fusionauth.io/docs/quickstarts/" rel="nofollow ugc">https://fusionauth.io/docs/quickstarts/</a></p>
<p dir="auto">I have Docker open,  I have the Fusion Auth main screen open.</p>
<p dir="auto">The first 2 screens from the 5 minute guide are shown below:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1702763172243-334af1db-4b61-4f23-8530-96d8e4d569e7-pict1.jpg" alt="334af1db-4b61-4f23-8530-96d8e4d569e7-pict1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1702762840947-781e5de2-d4fc-4a26-8d83-74de350ff501-image.png" alt="781e5de2-d4fc-4a26-8d83-74de350ff501-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The second screen is asking me to enter  "- node -v".  I have tried this in the Command Prompt and that didn't work.  How do I do this.?</p>
<p dir="auto">Mike</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2583/fusion-5-minute-guide</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 05:18:37 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2583.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Dec 2023 21:49:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fusion 5 minute guide on Mon, 18 Dec 2023 14:41:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3645">@support-2</a> this will be on your machine that you are running using <code>node</code>.</p>
<p dir="auto">If you need node installed locally you can use this<br />
<a href="https://nodejs.org/en/learn/getting-started/how-to-install-nodejs" rel="nofollow ugc">https://nodejs.org/en/learn/getting-started/how-to-install-nodejs</a></p>
<p dir="auto">If you are on a Mac and use homebrew<br />
<a href="https://formulae.brew.sh/formula/node" rel="nofollow ugc">https://formulae.brew.sh/formula/node</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/6867</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6867</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 18 Dec 2023 14:41:40 GMT</pubDate></item></channel></rss>
