<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Node Version Compatibility]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Which minimum Node JS version is required related to fusion Auth working with SDK in community version as we have old version of node JS 10.x, 12.x or 13.x so we need to check fusion AUTH related to these versions.</p>
<p dir="auto">Also I need to ask same for express JS version as well.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2592/node-version-compatibility</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 02:47:38 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2592.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Dec 2023 08:17:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Node Version Compatibility on Sat, 28 Mar 2026 10:06:54 GMT]]></title><description><![CDATA[<p dir="auto">I ran into a similar issue recently while trying to upgrade my stack. It seems like FusionAuth is generally pretty stable on the LTS versions, but things can get a bit 'interesting' if you're jumping to the absolute latest bleeding-edge Node release before they've officially validated it.<br />
I've found that sticking to the even-numbered LTS releases usually saves a lot of headache with the client libraries. Are you seeing specific crash logs, or is it just a dependency resolution error during the build?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8536</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8536</guid><dc:creator><![CDATA[sjames05569]]></dc:creator><pubDate>Sat, 28 Mar 2026 10:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to Node Version Compatibility on Wed, 26 Nov 2025 12:58:32 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Patterson said in <a href="/community/forum/post/6907">Node Version Compatibility</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2788">@max-0</a> our SDK package.json can be found here <a href="https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json</a></p>
<p dir="auto">In reality, we don't impose any limitations on a client, if something doesn't work well with your setup you can always exit from the SDK strategy and call the API's directly.</p>
<p dir="auto">Thanks for the clarification! Good to know we can always call the APIs directly if needed.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8429</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8429</guid><dc:creator><![CDATA[johnsmithui]]></dc:creator><pubDate>Wed, 26 Nov 2025 12:58:32 GMT</pubDate></item><item><title><![CDATA[Reply to Node Version Compatibility on Wed, 06 Mar 2024 10:24:18 GMT]]></title><description><![CDATA[<p dir="auto">@alex-patterson said in <a href="/community/forum/post/6907">Node Version Compatibility</a>:</p>
<p dir="auto">Hello! I think I should contact customer service</p>
]]></description><link>https://fusionauth.io/community/forum/post/7102</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7102</guid><dc:creator><![CDATA[polinkuer12]]></dc:creator><pubDate>Wed, 06 Mar 2024 10:24:18 GMT</pubDate></item><item><title><![CDATA[Reply to Node Version Compatibility on Thu, 22 Feb 2024 09:03:41 GMT]]></title><description><![CDATA[<p dir="auto">@alex-patterson said in <a href="/community/forum/post/6907">Node Version Compatibility</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2788">@max-0</a> our SDK package.json can be found here <a href="https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json</a> <a href="https://geometrydash-scratch.com" rel="nofollow ugc">geometry dash scratch</a></p>
<p dir="auto">Great! This is what I'm looking for</p>
]]></description><link>https://fusionauth.io/community/forum/post/7073</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7073</guid><dc:creator><![CDATA[daenerystargaryen56]]></dc:creator><pubDate>Thu, 22 Feb 2024 09:03:41 GMT</pubDate></item><item><title><![CDATA[Reply to Node Version Compatibility on Tue, 26 Dec 2023 18:40:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2788">@max-0</a> our SDK package.json can be found here <a href="https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-typescript-client/blob/master/package.json</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/6907</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6907</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 26 Dec 2023 18:40:44 GMT</pubDate></item></channel></rss>
