<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Elastic documentation is pretty abismal. Has anyone found better packages or workarounds?]]></title><description><![CDATA[<p dir="auto">I've spent the better part of a day trying to install a fleet server that Elastic prompted me to create after successfully installing/running search &amp; kibana.</p>
<p dir="auto">I'm about to altogether abandon fusionauth out of frustration over a couple of optional packages, but thought to reach out to you all first.</p>
<p dir="auto">thanks in advance.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2596/elastic-documentation-is-pretty-abismal-has-anyone-found-better-packages-or-workarounds</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 08:44:17 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2596.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jan 2024 18:01:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Elastic documentation is pretty abismal. Has anyone found better packages or workarounds? on Tue, 09 Jan 2024 17:56:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2801">@admin-9</a> I'm sorry to hear you're frustrated.</p>
<p dir="auto">However, I don't know what you mean by a fleet server.</p>
<p dir="auto">You have a couple of options:</p>
<li>you can test FusionAuth with the database search option, which doesn't require elasticsearch, but offers more limited search capabilities: <a href="https://fusionauth.io/docs/lifecycle/manage-users/search/search#using-the-database-search-engine" rel="nofollow ugc">https://fusionauth.io/docs/lifecycle/manage-users/search/search#using-the-database-search-engine</a></li>
<li>you could use our docker compose examples which are preconfigured to work with opensearch or elasticsearch: <a href="https://fusionauth.io/docs/get-started/download-and-install/docker" rel="nofollow ugc">https://fusionauth.io/docs/get-started/download-and-install/docker</a></li>
<p dir="auto">If you can provide a few more details about what you are trying to accomplish, I might be able to offer more guidance.</p>
]]></description><link>https://fusionauth.io/community/forum/post/6967</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/6967</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 09 Jan 2024 17:56:12 GMT</pubDate></item></channel></rss>
