<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error getting list application due to sql error (mysql)]]></title><description><![CDATA[<p dir="auto">When accessing app list in admin, it says.</p>
<p dir="auto">FusionAuth encountered an unexpected error. Please review the troubleshooting guide found in the documentation for assistance and the available support channels.</p>
<p dir="auto">here's the trace:</p>
<pre><code>org.apache.ibatis.exceptions.PersistenceException:
fusionauth-fusionauth-1     | ### Error querying database.  Cause: java.sql.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '&gt;&gt; '$.state' = 'Active'' at line 8
fusionauth-fusionauth-1     | ### The error may exist in io/fusionauth/api/domain/ApplicationMapper.xml
fusionauth-fusionauth-1     | ### The error may involve defaultParameterMap
fusionauth-fusionauth-1     | ### The error occurred while setting parameters
fusionauth-fusionauth-1     | ### SQL: SELECT COUNT(*)     FROM applications AS a      WHERE  LOWER(a.name) LIKE ?                                         AND a.data -&gt;&gt; '$.state' = ?
fusionauth-fusionauth-1     | ### Cause: java.sql.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '&gt;&gt; '$.state' = 'Active'' at line 8
fusionauth-fusionauth-1     |   at org.apache.ibatis.exceptions.ExceptionFactory.wrapException(ExceptionFactory.java:30)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:156)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:147)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:142)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.defaults.DefaultSqlSession.selectOne(DefaultSqlSession.java:75)
fusionauth-fusionauth-1     |   at jdk.internal.reflect.GeneratedMethodAccessor19.invoke(Unknown Source)
fusionauth-fusionauth-1     |   at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
fusionauth-fusionauth-1     |   at java.base/java.lang.reflect.Method.invoke(Method.java:568)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:355)
fusionauth-fusionauth-1     |   at jdk.proxy2/jdk.proxy2.$Proxy99.selectOne(Unknown Source)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.SqlSessionManager.selectOne(SqlSessionManager.java:164)
fusionauth-fusionauth-1     |   at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:87)
fusionauth-fusionauth-1     |   at org.apache.ibatis.binding.MapperProxy$PlainMethodInvoker.invoke(MapperProxy.java:142)
fusionauth-fusionauth-1     |   at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:86)
fusionauth-fusionauth-1     |   at jdk.proxy2/jdk.proxy2.$Proxy118.retrieveCountByCriteria(Unknown Source)
fusionauth-fusionauth-1     |   at io.fusionauth.api.service.system.DefaultApplicationReaderService.search(DefaultApplicationReaderService.java:107)
fusionauth-fusionauth-1     |   at io.fusionauth.app.action.api.application.SearchAction.search(SearchAction.java:79)
fusionauth-fusionauth-1     |   at io.fusionauth.app.action.api.BaseSearchAPIAction.post(BaseSearchAPIAction.java:56)
fusionauth-fusionauth-1     |   at jdk.internal.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:79)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:119)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:65)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:108)
fusionauth-fusionauth-1     |   at org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:73)
fusionauth-fusionauth-1     |   at io.fusionauth.http.server.HTTPWorker.run(HTTPWorker.java:50)
fusionauth-fusionauth-1     |   at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
fusionauth-fusionauth-1     |   at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
fusionauth-fusionauth-1     |   at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
fusionauth-fusionauth-1     |   at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
fusionauth-fusionauth-1     |   at java.base/java.lang.Thread.run(Thread.java:833)
fusionauth-fusionauth-1     | Caused by: java.sql.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '&gt;&gt; '$.state' = 'Active'' at line 8
fusionauth-fusionauth-1     |   at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:121)
fusionauth-fusionauth-1     |   at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
fusionauth-fusionauth-1     |   at com.mysql.cj.jdbc.ClientPreparedStatement.executeInternal(ClientPreparedStatement.java:912)
fusionauth-fusionauth-1     |   at com.mysql.cj.jdbc.ClientPreparedStatement.execute(ClientPreparedStatement.java:354)
fusionauth-fusionauth-1     |   at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44)
fusionauth-fusionauth-1     |   at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.statement.PreparedStatementHandler.query(PreparedStatementHandler.java:65)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.statement.RoutingStatementHandler.query(RoutingStatementHandler.java:80)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:65)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:333)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:158)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:110)
fusionauth-fusionauth-1     |   at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:90)
fusionauth-fusionauth-1     |   at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:154)
fusionauth-fusionauth-1     |   ... 53 common frames omitted
fusionauth-fusionauth-1     | 2024-02-13 02:47:44.565 AM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
fusionauth-fusionauth-1     | org.apache.ibatis.exceptions.PersistenceException:
<p dir="auto">I think this because <code>-</code> in <code>a.data -&gt;&gt; '$.state' = ?</code>.<br />
Any way to fix this?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2617/error-getting-list-application-due-to-sql-error-mysql</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 04:34:40 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2617.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Feb 2024 02:54:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error getting list application due to sql error (mysql) on Wed, 28 Jan 2026 16:12:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> said in <a href="/community/forum/post/7048">Error getting list application due to sql error (mysql)</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2854">@traperwaze</a> said in <a href="/community/forum/post/7044">Error getting list application due to sql error (mysql)</a>:</p>
<p dir="auto">MariaDB server</p>
<p dir="auto">I believe the issues is that we don't support MariaDB.</p>
<p dir="auto">This is a known issue: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/367" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/367</a> <a href="https://poki.pw/" rel="nofollow ugc">poki</a></p>
<p dir="auto">Do you see the same issue with a <a href="https://fusionauth.io/docs/get-started/download-and-install/system-requirements#database" rel="nofollow ugc">supported version of MySQL or PostgreSQL</a>?</p>
<p dir="auto">Thanks for confirming. That lines up with what I’m seeing as well. We are indeed running MariaDB, and it looks like the JSON operator (-&gt;&gt;) used in that query isn’t supported the same way in MariaDB, which would explain the syntax error.</p>
<p dir="auto">We haven’t tested this yet on a supported database, but based on the linked issue and your comment, it does appear to be a MariaDB compatibility problem rather than a misconfiguration on our side. We’ll plan to test against a supported version of MySQL and/or PostgreSQL to confirm.</p>
<p dir="auto">Appreciate you pointing us to the GitHub issue — that helps clarify things a lot.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8489</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8489</guid><dc:creator><![CDATA[rossomaciato]]></dc:creator><pubDate>Wed, 28 Jan 2026 16:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to Error getting list application due to sql error (mysql) on Tue, 27 Feb 2024 10:22:09 GMT]]></title><description><![CDATA[<p dir="auto">I have similar issue with MySql 5.7 and create a issue report here : <a href="https://github.com/FusionAuth/fusionauth-issues/issues/2658" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/2658</a></p>
<p dir="auto">Apparently it seem there is typing error in Sql query that miss the table name but use the alias only and hence the error.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7086</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7086</guid><dc:creator><![CDATA[truearrowsoftware]]></dc:creator><pubDate>Tue, 27 Feb 2024 10:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to Error getting list application due to sql error (mysql) on Sat, 17 Feb 2024 17:23:05 GMT]]></title><description><![CDATA[<p dir="auto">It seems like there's a SQL error preventing the application list from being retrieved.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7061</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7061</guid><dc:creator><![CDATA[cabmanlsoverrunsls]]></dc:creator><pubDate>Sat, 17 Feb 2024 17:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to Error getting list application due to sql error (mysql) on Wed, 14 Feb 2024 03:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2854">@traperwaze</a> said in <a href="/community/forum/post/7044">Error getting list application due to sql error (mysql)</a>:</p>
<p dir="auto">This is a known issue: <a href="https://github.com/FusionAuth/fusionauth-issues/issues/367" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/367</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7048</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7048</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 14 Feb 2024 03:58:42 GMT</pubDate></item></channel></rss>
