<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Proxy Configuration Warning]]></title><description><![CDATA[<p dir="auto">I have installed a test FusionAuth as a docker in Portainer, and am using NGINX Proxy Manager (also in Portainer) to proxy to it. The headers have been set, but am still getting the warning. It says to correct the origin, add the following request headers, which I have done - the only one it shows is X-Forwarded-Port: 443, this is set in the headers and can be seen when the headers are queried.</p>
<p dir="auto">the only difference between the Reported request origin and Actual request origin is that the latter one also shows the port number.</p>
<p dir="auto">I have looked at the other postings for this error, but no solution works.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2619/proxy-configuration-warning</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 08:50:52 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2619.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Feb 2024 16:39:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Proxy Configuration Warning on Tue, 08 Oct 2024 23:04:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Has there been any updates on this? I have my fusionauth application in cluster behind a proxy (nginx ingress controller) and I passing those same headers but I am getting a CSRF error. Please any help is more than welcome.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7539</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7539</guid><dc:creator><![CDATA[skibirige]]></dc:creator><pubDate>Tue, 08 Oct 2024 23:04:24 GMT</pubDate></item><item><title><![CDATA[Reply to Proxy Configuration Warning on Wed, 06 Mar 2024 20:39:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2855">@jawaid-karim</a> Hmmm. Those all look good.</p>
<p dir="auto">So you are still seeing an error in the admin screen when you log in?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7111</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7111</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 06 Mar 2024 20:39:35 GMT</pubDate></item><item><title><![CDATA[Reply to Proxy Configuration Warning on Mon, 26 Feb 2024 10:42:53 GMT]]></title><description><![CDATA[<p dir="auto">Dealing with proxy setups can be tricky. Have you tried adjusting the NGINX Proxy Manager settings to ensure it correctly forwards the port number in the request origin? Sometimes, it's a matter of fine-tuning those configurations.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7082</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7082</guid><dc:creator><![CDATA[pppp66535]]></dc:creator><pubDate>Mon, 26 Feb 2024 10:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to Proxy Configuration Warning on Wed, 14 Feb 2024 16:17:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> I have the following headers setup:</p>
<p dir="auto">X-Forwarded-Port          443<br />
X-Forwarded-Host          <a href="http://fusion.mydomain.com" rel="nofollow ugc">fusion.mydomain.com</a><br />
X-Forwarded-Proto         https<br />
X-Forwarded-For             my_public_ip<br />
X-Forwarded-Server        <a href="http://fusion.mydomain.com" rel="nofollow ugc">fusion.mydomain.com</a></p>
<p dir="auto">FusionAuth Version is 1.48.3</p>
]]></description><link>https://fusionauth.io/community/forum/post/7053</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7053</guid><dc:creator><![CDATA[jawaid.karim]]></dc:creator><pubDate>Wed, 14 Feb 2024 16:17:04 GMT</pubDate></item><item><title><![CDATA[Reply to Proxy Configuration Warning on Wed, 14 Feb 2024 04:05:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2855">@jawaid-karim</a> What headers have you set in NGINX to send to FusionAuth? What FusionAuth version are you running?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7051</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7051</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 14 Feb 2024 04:05:03 GMT</pubDate></item></channel></rss>
