<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bulk Delete &#x2F; Reactivate]]></title><description><![CDATA[<p dir="auto">you can bulk soft delete users, but can you bulk reactivate them?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2622/bulk-delete-reactivate</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 04:55:53 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2622.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Feb 2024 22:50:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bulk Delete &#x2F; Reactivate on Thu, 02 Apr 2026 11:55:30 GMT]]></title><description><![CDATA[<p dir="auto">Managing users in bulk can definitely be a bit nerve-wracking when you're doing it for the first time.<br />
If you’re looking for a quick way to handle this, the FusionAuth Search API is probably your best friend here. You can run a query to get the IDs of the users you want to target, and then loop through them with a simple script using the Delete User API.<br />
If you just want to "deactivate" them instead of a hard delete, you can toggle the active flag to false in the User object. This is usually a safer bet if you think you might need to reactivate them later without losing all their historical data or linked identities. Just a heads-up: make sure you have a good backup of your database before running any bulk scripts—it's saved my skin more than once!</p>
]]></description><link>https://fusionauth.io/community/forum/post/8541</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8541</guid><dc:creator><![CDATA[sjames05569]]></dc:creator><pubDate>Thu, 02 Apr 2026 11:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to Bulk Delete &#x2F; Reactivate on Mon, 05 Aug 2024 16:24:50 GMT]]></title><description><![CDATA[<p dir="auto">thanks for sharing...</p>
]]></description><link>https://fusionauth.io/community/forum/post/7422</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7422</guid><dc:creator><![CDATA[reply 0]]></dc:creator><pubDate>Mon, 05 Aug 2024 16:24:50 GMT</pubDate></item><item><title><![CDATA[Reply to Bulk Delete &#x2F; Reactivate on Fri, 19 Jul 2024 08:54:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> said in <a href="/community/forum/post/7066">Bulk Delete / Reactivate</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2007">@randall</a> It does not look like there is a bulk reactive. I thought you might be able to use the Import Users API, but it looks like it will throw errors on duplicates. Looks like you will have to loop through the users to enable them.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/apis/users#reactivate-a-user" rel="nofollow ugc">https://fusionauth.io/docs/apis/users#reactivate-a-user</a> <a href="https://geometrydashworld.net" rel="nofollow ugc">geometry dash world</a></p>
<p dir="auto">Thanks for this guide. This is what I need.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7391</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7391</guid><dc:creator><![CDATA[peanutsunless]]></dc:creator><pubDate>Fri, 19 Jul 2024 08:54:15 GMT</pubDate></item><item><title><![CDATA[Reply to Bulk Delete &#x2F; Reactivate on Wed, 21 Feb 2024 03:07:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2007">@randall</a> It does not look like there is a bulk reactive. I thought you might be able to use the Import Users API, but it looks like it will throw errors on duplicates. Looks like you will have to loop through the users to enable them.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/apis/users#reactivate-a-user" rel="nofollow ugc">https://fusionauth.io/docs/apis/users#reactivate-a-user</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7066</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7066</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 21 Feb 2024 03:07:05 GMT</pubDate></item></channel></rss>
