<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Why does import user with Registration fail?]]></title><description><![CDATA[<p dir="auto">I'm creating a Role for the default Application like so, and then trying to import a user:</p>
<pre><code class="language-js">import {FusionAuthClient} from '@fusionauth/typescript-client';
const applicationId = 'e9fdb985-9173-4e01-9d73-ac2d60d1dc8e';
const subscriberRoleId = '635ef5c8-54c5-4605-ba0f-add6ad1578ce';
const apiKey = '33052c8a-c283-4e96-9d2a-eb1215c69f8f-not-for-prod';
const fusionauthUrl = 'http://localhost:9011';
const fa = new FusionAuthClient(apiKey, fusionauthUrl);
await fa.createApplicationRole(applicationId, subscriberRoleId, { role: {
    isDefault: false,
    isSuperRole: false,
    description: 'Subscriber'
const importRequest = { users: [user], validateDbConstraints: true };
const result = await fa.importUsers(importRequest);
<p dir="auto">Importing without user Registrations works fine, but as soon as I add a Registration, I get this error:</p>
<pre><code class="language-sh">fieldErrors: {
      'user.registrations.roles': [
          code: '[invalid]user.registrations.roles',
          message: 'Invalid Application role(s) [635ef5c8-54c5-4605-ba0f-add6ad1578ce (app: ExampleNodeApp)].'
    generalErrors: []
<p dir="auto">Here is the user I'm importing in JSON:</p>
<pre><code class="language-json">{"email":"a@example.com",
"encryptionScheme":"example-wordpress-phpass",
"factor":8,"password":"JFAkQi9rQ3pUTURWN2NjQ2xhUlNoSlB6OHN1V1FkS2M1Lw==",
"salt":"JFAkQi9rQ3pUTURWN2NjQ2xhUlNoSlB6OHN1V1FkS2M1Lw==",
"uniqueUsername":"a",
"username":"a",
"verified":false,
"active":true,
"registrations":[{"applicationId":"e9fdb985-9173-4e01-9d73-ac2d60d1dc8e","roles":["635ef5c8-54c5-4605-ba0f-add6ad1578ce"]}],
"data":{"WordPress_ID":2,"WordPress_user_nicename":"a","WordPress_user_registered":"2024-02-21 10:52:53","WordPress_display_name":"a","WordPress_nickname":"a","WordPress_wp_capabilities":{"subscriber":true},"WordPress_default_password_nag":"1"}}
<p dir="auto">What must I change in my import user to get this to work please? The applicationId is correct and the roleId, I've checked in the web interface.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2630/why-does-import-user-with-registration-fail</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 11:26:59 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2630.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Feb 2024 08:48:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Why does import user with Registration fail? on Fri, 01 Mar 2024 17:03:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2884">@fusionauth-qhj5e</a> I have brought this up internally, for now we are considering adding a PR to make it more clear for users.</p>
<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-site/pull/2918" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-site/pull/2918</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7095</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7095</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 01 Mar 2024 17:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to Why does import user with Registration fail? on Fri, 01 Mar 2024 16:43:05 GMT]]></title><description><![CDATA[<p dir="auto">@alex-patterson Thanks, this works. I thought the uuid would be better in case I ever change the role name though.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7094</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7094</guid><dc:creator><![CDATA[fusionauth.qhj5e]]></dc:creator><pubDate>Fri, 01 Mar 2024 16:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to Why does import user with Registration fail? on Fri, 01 Mar 2024 16:34:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2884">@fusionauth-qhj5e</a> I am checking with the team if you indeed should be able to send in the Id for the role as you are in the example. For now you should be able to add <code>Subscriber</code> which is the name of your new role.</p>
<p dir="auto">Here is a full example.</p>
<pre><code>app.get('/registration', async (req, res, next) =&gt; {
  let returnResult;
  try {
    // make sure to remove role each time
    await fa.deleteApplicationRole(applicationId,subscriberRoleId);
    // add role
        isDefault: false,
        isSuperRole: false,
    const user = {
      "email": "a@example.com",
      "encryptionScheme": "phpass-md5", // I updated this from wordpress
      "factor": 8, "password": "JFAkQi9rQ3pUTURWN2NjQ2xhUlNoSlB6OHN1V1FkS2M1Lw==",
      "salt": "JFAkQi9rQ3pUTURWN2NjQ2xhUlNoSlB6OHN1V1FkS2M1Lw==",
      "uniqueUsername": "a",
      "username": "a",
      "verified": false,
      "active": true,
      "registrations": [{ "applicationId": applicationId, "roles": ['Subscriber'] }],
      "data": { "WordPress_ID": 2, "WordPress_user_nicename": "a", "WordPress_user_registered": "2024-02-21 10:52:53", "WordPress_display_name": "a", "WordPress_nickname": "a", "WordPress_wp_capabilities": { "subscriber": true }, "WordPress_default_password_nag": "1" }
    console.log("result", result)
    returnResult = result;
  } catch (e) {
    returnResult = JSON.stringify(e);
    console.error("error", returnResult);
  res.json(JSON.stringify({
    returnResult
<p dir="auto">Please also take note you may need to update your <code>encryptionScheme</code> to <code>phpass-md5</code> as I believe this is what will come from Wordpress.</p>
<p dir="auto">You can find more details <a href="https://fusionauth.io/docs/reference/password-hashes" rel="nofollow ugc">https://fusionauth.io/docs/reference/password-hashes</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7093</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7093</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 01 Mar 2024 16:34:45 GMT</pubDate></item></channel></rss>
