<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to listen FusionAuth webhook in C#]]></title><description><![CDATA[<p dir="auto">I need to listen FusionAuth webhook in <a href="http://ASP.Net" rel="nofollow ugc">ASP.Net</a> Core C#.  But, I do not find C# model to map the body request from C# web controller</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2662/how-to-listen-fusionauth-webhook-in-c</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:48:35 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2662.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Apr 2024 20:53:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to listen FusionAuth webhook in C# on Thu, 02 May 2024 12:56:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2990">@vandaele-seba</a> Could be better that this model exists in FusionAuth C# library. To be sure have a compliant model with new FusionAuth versions</p>
]]></description><link>https://fusionauth.io/community/forum/post/7222</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7222</guid><dc:creator><![CDATA[didier]]></dc:creator><pubDate>Thu, 02 May 2024 12:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to How to listen FusionAuth webhook in C# on Tue, 30 Apr 2024 16:49:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/668">@didier</a> Hello, to see the templates you need to create you can go to this link http://{yourhost}/admin/webhook/test/{your-webhook-id}<br />
You should arrive on this page, and you can test all the events directly from this page.</p>
<p dir="auto">Then all you have to do is create your C# object corresponding to the field you're interested in.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1714495686679-bc0263a5-de44-4fc8-af35-d95cab825ad8-image-resized.png" alt="bc0263a5-de44-4fc8-af35-d95cab825ad8-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/7216</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7216</guid><dc:creator><![CDATA[vandaele.seba]]></dc:creator><pubDate>Tue, 30 Apr 2024 16:49:54 GMT</pubDate></item></channel></rss>
