<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[API Keys page 500]]></title><description><![CDATA[<p dir="auto">Hello, for some reason the API keys page throws 500 error with this stack trace</p>
<pre><code>2024-05-07 12:25:32.747 PM ERROR io.fusionauth.app.primeframework.error.ExceptionExceptionHandler - An unhandled exception was thrown
### Error querying database.  Cause: org.postgresql.util.PSQLException: ERROR: column "key" does not exist
  Position: 804
### The error may exist in io/fusionauth/api/domain/APIKeyMapper.xml
### The error may involve defaultParameterMap
### The error occurred while setting parameters
### SQL: SELECT k.id                         AS k_id,            k.insert_instant             AS k_insert_instant,            k.ip_access_control_lists_id AS k_ip_access_control_lists_id,            k.last_update_instant        AS k_last_update_instant,            k.key_manager                AS k_key_manager,            k.key_value                  AS k_key_value,            k.tenants_id                 AS k_tenants_id,            k.permissions                AS k_permissions,            k.meta_data                  AS k_meta_data       FROM authentication_keys AS k          WHERE  (         k.meta_data IS NULL         OR NOT (k.meta_data::JSONB ?? 'attributes'            AND k.meta_data::JSONB -&gt; 'attributes' ??| array['internalCacheReloader', 'internalLogDownloader'])         )              ORDER BY key desc                   LIMIT ?                   OFFSET ?
### Cause: org.postgresql.util.PSQLException: ERROR: column "key" does not exist
  Position: 804
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:156)
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:147)
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:142)
	at jdk.internal.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
	at java.base/java.lang.reflect.Method.invoke(Method.java:568)
	at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:355)
	at jdk.proxy2/jdk.proxy2.$Proxy54.selectList(Unknown Source)
	at org.apache.ibatis.session.SqlSessionManager.selectList(SqlSessionManager.java:204)
	at org.apache.ibatis.binding.MapperMethod.executeForMany(MapperMethod.java:147)
	at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:80)
	at org.apache.ibatis.binding.MapperProxy$PlainMethodInvoker.invoke(MapperProxy.java:141)
	at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:86)
	at jdk.proxy2/jdk.proxy2.$Proxy59.retrieveByCriteria(Unknown Source)
	at io.fusionauth.api.service.system.DefaultAPIKeyReaderService.search(DefaultAPIKeyReaderService.java:66)
	at io.fusionauth.app.action.admin.apiKey.IndexAction.search(IndexAction.java:51)
	at io.fusionauth.app.action.admin.BaseSearchAction.execute(BaseSearchAction.java:77)
	at jdk.internal.reflect.GeneratedMethodAccessor129.invoke(Unknown Source)
	at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443)
	at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77)
	at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60)
	at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50)
	at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50)
	at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45)
	at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:79)
	at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49)
	at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74)
	at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58)
	at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92)
	at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50)
	at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:119)
	at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65)
	at org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:65)
	at org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:108)
	at org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:73)
	at io.fusionauth.http.server.HTTPWorker.run(HTTPWorker.java:50)
	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
	at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: org.postgresql.util.PSQLException: ERROR: column "key" does not exist
  Position: 804
	at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2725)
	at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2412)
	at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:371)
	at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:502)
	at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:419)
	at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:194)
	at org.postgresql.jdbc.PgPreparedStatement.execute(PgPreparedStatement.java:180)
	at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44)
	at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java)
	at org.apache.ibatis.executor.statement.PreparedStatementHandler.query(PreparedStatementHandler.java:65)
	at org.apache.ibatis.executor.statement.RoutingStatementHandler.query(RoutingStatementHandler.java:80)
	at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:65)
	at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:336)
	at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:158)
	at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:110)
	at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:90)
	at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:154)
	... 53 common frames omitted
<p dir="auto">I don't think we've change anything and we are using cloud instance. Any idea how to fix this ?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2672/api-keys-page-500</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 16:12:58 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2672.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2024 12:35:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to API Keys page 500 on Mon, 27 May 2024 08:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Yes, it works as temporary solution. Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/post/7307</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7307</guid><dc:creator><![CDATA[zaalbarxx]]></dc:creator><pubDate>Mon, 27 May 2024 08:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to API Keys page 500 on Wed, 08 May 2024 16:16:04 GMT]]></title><description><![CDATA[<p dir="auto">@cierzniak I think you found a bug! <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1846">@spencer</a> filed an issue that looks related.</p>
<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-issues/issues/2738" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/2738</a></p>
<p dir="auto">There's a workaround in the issue, which involves deleting a cookie.</p>
<p dir="auto">Can you please try that and let us know if that resolves it?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7236</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7236</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 08 May 2024 16:16:04 GMT</pubDate></item></channel></rss>
