<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Login stopped working - &#96;missing_code&#96; error using SDK]]></title><description><![CDATA[<p dir="auto">Hi, another day, another problem <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
Suddenly the login stopped working for some reason (no dependencies changed and I believe no settings for FusionAuth too)</p>
<p dir="auto">Using Vue SDK this login redirect URL is generated:<br />
<code>http://localhost:9011/app/login?client_id=e9d1e58d-d076-439a-b92d-a0e5f76cceef&amp;redirect_uri=http%3A%2F%2Flocalhost%3A3010%2Fauth%2Fcallback&amp;scope=offline_access+openid+email&amp;state=redirect_to%253Dtrue</code></p>
<p dir="auto">The browser redirects to this address then redirect back to <code>http://localhost:3010/auth/callback </code> with this query string:<br />
<code>{ error: 'invalid_request',   error_description: 'The request is missing a required parameter: code',   error_reason: 'missing_code',   state: 'redirect_to%3D%2F' }</code></p>
<p dir="auto">Everything seemed to work fine up until now and I cannot find any related issue.<br />
Application do have PKCE set as not required as on the screenshot:<br />
<img src="/community/forum/assets/uploads/files/1716823959925-ae102210-5b12-4c52-9b33-15f517c3bafc-image.png" alt="ae102210-5b12-4c52-9b33-15f517c3bafc-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is an event from the event log:</p>
<pre><code>Unable to complete app login. The auth code exchange has failed.
Application Id: e9d1e58d-d076-439a-b92d-a0e5f76cceef
Status code [400]
Error response is
  "error" : "invalid_request",
  "error_description" : "The request is missing a required parameter: code",
  "error_reason" : "missing_code"
<p dir="auto">Changing the enabled grants from <code>Authorization code</code> to <code>Password</code> changes the error query to:</p>
<pre><code>{ error: 'unauthorized_client',
  error_description:
   'The [authorization_code] Authorization Code grant has been disabled for this client.',
  error_reason: 'grant_type_disabled',
<p dir="auto">but I guess since <code>Authorization code</code> was working previously and <code>password</code> grant is "legacy", I should use former.</p>
<p dir="auto">Edit: From what I see the problem starts to appear right after I update Terraform provider from 0.1.105 to 0.1.106. When I change to 0.1.105 to it starts to work properly.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2693/login-stopped-working-missing_code-error-using-sdk</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 14:48:43 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2693.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 May 2024 15:33:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Login stopped working - &#96;missing_code&#96; error using SDK on Wed, 29 May 2024 09:04:54 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Patterson No, I've been using <code>1.50.1</code> version of FusionAuth (read from the admin panel) all the time. The only thing that changed was provider version. Like I said I can just switch between versions and it will start/stop working immediately, so I assume that version 0.1.106 may add some implicit parameter which changes something.<br />
I just checked it after using <code>docker-compose down -v</code> and <code>docker-compose up</code> (fresh installation) and after running the Terraform the error still persists. What's interesting is that I've checked the diff between <code>0.1.105</code> and <code>0.1.106</code> on FusionAuth Terraform repo <a href="https://github.com/FusionAuth/terraform-provider-fusionauth/compare/v0.1.105...v0.1.106" rel="nofollow ugc">https://github.com/FusionAuth/terraform-provider-fusionauth/compare/v0.1.105...v0.1.106</a> and it does not seem that anything that could be related was changed there, maybe it is related to Go client or something ?</p>
<p dir="auto">EDIT:<br />
Ok, I found the culprit, looks like between 0.1.105 and 0.1.106 there is some change that automatically sets this to either false (106) or true (105):</p>
<p dir="auto"><code>Application -&gt; Scopes -&gt; Provided Scopes</code><br />
Here there are some default scopes, <code>address</code>, <code>email</code>, <code>phone</code> and <code>profile</code>.</p>
<p dir="auto">The problem here is that it looks like the Terraform provider currently does not allow to set these variables in schema, so basically we are blocked between older version with unsupported configurations like theme's <code>oauth_consent</code> and newer version which handles these scopes inproperly (we can change it manually, but obviously each deployment will cause the values to reset back to false).</p>
<p dir="auto"><a href="https://github.com/FusionAuth/terraform-provider-fusionauth/issues/277" rel="nofollow ugc">https://github.com/FusionAuth/terraform-provider-fusionauth/issues/277</a></p>
<p dir="auto">I hope this will get resolved quickly since right now it is quite a blocker.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7319</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7319</guid><dc:creator><![CDATA[zaalbarxx]]></dc:creator><pubDate>Wed, 29 May 2024 09:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to Login stopped working - &#96;missing_code&#96; error using SDK on Tue, 28 May 2024 15:03:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3001">@zaalbarxx</a> During this time did your FusionAuth version change with the Terraform update? Possibly pulling the latest image?</p>
<p dir="auto"><a href="https://fusionauth.io/docs/release-notes/#version-1-50-0" rel="nofollow ugc">https://fusionauth.io/docs/release-notes/#version-1-50-0</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7311</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7311</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 28 May 2024 15:03:32 GMT</pubDate></item></channel></rss>
