<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error in startup after upgrading to 1.51.2]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I was running version 1.48.3 and am trying to upgrade to 1.51.2 because of the vulnerability. After upgrading the version in my Dockerfile, and restarting the container, I am getting an error in the log file. My database is a Postgres database on Azure.</p>
<pre><code> ---------------------------------------------------------------------------------------------------------
 --------------------------------- Starting FusionAuth version [1.51.2] ----------------------------------
 2024-07-13 09:45:07.295 AM INFO  io.fusionauth.api.plugin.guice.PluginModule - No plugins found
 2024-07-13 09:45:10.149 AM INFO  io.fusionauth.api.service.system.NodeService - Node [b936de13-c292-416e-acdb-8b18759cba97] started.
 2024-07-13 09:45:17.500 AM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties]
 2024-07-13 09:45:17.501 AM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [http://localhost:9011]
 2024-07-13 09:45:17.540 AM INFO  com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -
  - Overriding default value of property [fusionauth-app.runtime-mode] with value [production]
  - Overriding default value of property [search.type] with value [database]
 2024-07-13 09:45:17.662 AM INFO  com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://invoicingapi-db-server.postgres.database.azure.com:5432/fusionauth]
 2024-07-13 09:45:17.692 AM WARN  com.zaxxer.hikari.HikariConfig - HikariPool-1 - idleTimeout has been set but has no effect because the pool is operating as a fixed size pool.
 2024-07-13 09:45:17.711 AM INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
 2024-07-13 09:45:20.528 AM INFO  com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Added connection org.postgresql.jdbc.PgConnection@6579cdbb
 2024-07-13 09:45:20.577 AM INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed.
 2024-07-13 09:45:37.031 AM INFO  com.inversoft.scheduler.DefaultScheduler - Starting up scheduler
 2024-07-13 09:45:37.033 AM INFO  com.inversoft.scheduler.DefaultScheduler - Scheduler is running
 2024-07-13 09:45:37.203 AM ERROR com.inversoft.scheduler.LogAndRetainFailureHandler - The scheduled service [class io.fusionauth.api.service.cache.ApplicationCacheLoader] failed but will be re-run.
 ### Error querying database.  Cause: org.postgresql.util.PSQLException: ERROR: column a.userinfo_populate_lambdas_id does not exist
   Position: 3467
 ### The error may exist in io/fusionauth/api/domain/ApplicationMapper.xml
 ### The error may involve defaultParameterMap
 ### The error occurred while setting parameters
<p dir="auto">I'm not sure how to diagnose this issue. Is it obvious what has gone wrong?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2717/error-in-startup-after-upgrading-to-1-51-2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 14:52:11 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2717.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Jul 2024 10:14:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error in startup after upgrading to 1.51.2 on Tue, 06 Aug 2024 14:57:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2777">@ronn316</a> if you want to use silent mode during the upgrade</p>
<p dir="auto"><a href="https://fusionauth.io/docs/get-started/download-and-install/silent-mode" rel="nofollow ugc">https://fusionauth.io/docs/get-started/download-and-install/silent-mode</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7432</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7432</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 06 Aug 2024 14:57:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error in startup after upgrading to 1.51.2 on Fri, 16 Aug 2024 08:20:55 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Patterson That did the trick! Enabled silent mode in the fusionauth.properties file and no more errors.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7476</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7476</guid><dc:creator><![CDATA[ronn316]]></dc:creator><pubDate>Fri, 16 Aug 2024 08:20:55 GMT</pubDate></item><item><title><![CDATA[Reply to Error in startup after upgrading to 1.51.2 on Tue, 06 Aug 2024 14:57:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2777">@ronn316</a> if you want to use silent mode during the upgrade</p>
]]></description><link>https://fusionauth.io/community/forum/post/7432</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7432</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 06 Aug 2024 14:57:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error in startup after upgrading to 1.51.2 on Sat, 27 Jul 2024 06:41:08 GMT]]></title><description><![CDATA[<p dir="auto">@Alex-Patterson Hi. It's not clear to me exactly how to do the system upgrade. I'm running in Production mode. It says the following on your link: "In a production runtime mode, or with silent configuration enabled, the upgrade will occur automatically during startup."</p>
<p dir="auto">So I shouldn't need to do anything.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7399</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7399</guid><dc:creator><![CDATA[ronn316]]></dc:creator><pubDate>Sat, 27 Jul 2024 06:41:08 GMT</pubDate></item><item><title><![CDATA[Reply to Error in startup after upgrading to 1.51.2 on Mon, 15 Jul 2024 15:25:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2777">@ronn316</a> I believe there was an database change that was required in 1.50 <a href="https://fusionauth.io/docs/release-notes/#version-1-50-0" rel="nofollow ugc">https://fusionauth.io/docs/release-notes/#version-1-50-0</a></p>
<p dir="auto">You will need to check the upgrade info<br />
<a href="https://fusionauth.io/docs/operate/deploy/upgrade" rel="nofollow ugc">https://fusionauth.io/docs/operate/deploy/upgrade</a></p>
<p dir="auto">specifically the database migration in silent mode<br />
<a href="https://fusionauth.io/docs/operate/deploy/upgrade#downtime-and-database-migrations" rel="nofollow ugc">https://fusionauth.io/docs/operate/deploy/upgrade#downtime-and-database-migrations</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/7375</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7375</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 15 Jul 2024 15:25:30 GMT</pubDate></item></channel></rss>
