<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I am having issues upgrading my containerized version of FusionAuth]]></title><description><![CDATA[<p dir="auto">I'm seeing this message:</p>
<p dir="auto"><code>exec /usr/local/fusionauth/fusionauth-app/bin/start.sh: exec format error</code></p>
<p dir="auto">when I try to upgrade FusionAuth. I'm running containers.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2721/i-am-having-issues-upgrading-my-containerized-version-of-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 04:10:51 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2721.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Jul 2024 22:07:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I am having issues upgrading my containerized version of FusionAuth on Tue, 23 Jul 2024 19:09:14 GMT]]></title><description><![CDATA[<p dir="auto">Ensure that the source machine that is building your image is the correct architecture type.</p>
<li><a href="https://www.reddit.com/r/kubernetes/comments/13lurdl/kubernetes_error_exec_usrlocalbinyarn_exec_format/?rdt=39252" rel="nofollow ugc">https://www.reddit.com/r/kubernetes/comments/13lurdl/kubernetes_error_exec_usrlocalbinyarn_exec_format/?rdt=39252</a></li>
<p dir="auto">For instance, if you are building a K8's cluster running linux (x86) but have built the image locally on a Apple M2 Mac (ARM based), then you will need to instruct docker to use the <code>build x</code> command to build a multi-platform build or change the source build machine.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7385</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7385</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 23 Jul 2024 19:09:14 GMT</pubDate></item></channel></rss>
