<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Database search &quot;limitations&quot;]]></title><description><![CDATA[<p dir="auto">For cost reasons (etc.) we may not want to run dedicated OpenSearch instances in all of our deployed environments. I see in the <a href="https://fusionauth.io/docs/lifecycle/manage-users/search/search#using-the-database-search-engine" rel="nofollow ugc">documentation</a> that</p>
<p dir="auto">The database search engine is appropriate for systems that are not dependent on the FusionAuth APIs, are not expected to have a large number of search results, or are running in an embedded environment.</p>
<p dir="auto">I get the performance implications. What i'm curious about is</p>
<p dir="auto">The database search engine is appropriate for systems that are not dependent on the FusionAuth APIs...</p>
<p dir="auto">Are there API endpoints that don't work without OpenSearch?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2762/database-search-limitations</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 06:43:20 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2762.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Sep 2024 22:17:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Database search &quot;limitations&quot; on Wed, 23 Oct 2024 20:22:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3209">@tschlegel</a> There are differences between the database search engine and using open search.  Some of the searches are more limited with the database search engine.</p>
<p dir="auto">"If you don’t need advanced searching capabilities, you may be able to use the database search engine for large installations. This is not a use case FusionAuth tests, so ensure you provision your database with enough resources and benchmark your typical use cases."</p>
]]></description><link>https://fusionauth.io/community/forum/post/7580</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7580</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 23 Oct 2024 20:22:00 GMT</pubDate></item></channel></rss>
