<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lambda Login validation]]></title><description><![CDATA[<p dir="auto">Hi all !<br />
When I use the new  lambda "Login Validation" the template "authorize" display the message<br />
"A validation error occurred during the login attempt. An event log was created for the administrator to review"<br />
instead of display the "result.errors.generalErrors" on the screen.<br />
Is it normal ?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2778/lambda-login-validation</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 20:25:41 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2778.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Sep 2024 11:58:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lambda Login validation on Wed, 23 Oct 2024 19:56:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2727">@olivier-rochon</a> Would you be able to provide a little more detail? Does the error always occur or do you get that message only when an error occurs?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7578</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7578</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 23 Oct 2024 19:56:55 GMT</pubDate></item></channel></rss>
